Download AMD Radeon Software Crimson Edition 16.1 Hotfix verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.AMD Radeon Software Crimson Edition 16.1 Hotfix Release Notes incl. Downloadlinks für 32bit/64bit.
Compatible Operating Systems
AMD Radeon Software Crimson Edition 16.1 Hotfix Driver is designed to support the following Microsoft® Windows® platforms:
Windows® 10 (32 & 64-bit version)
Windows 8.1 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Resolved Issues
[82645] Fallout 4 – The compass flickers during gameplay on AMD Radeon™ R9 290 and AMD Radeon™ R9 295X2
[84118]/[59475] Elite: Dangerous - Poor performance may be experienced in Supercruise mode under Windows® 10
[82887] The driver installer appears to hang at various stages of the install process
[84116] Call of Duty: Black Ops 3 – random frame freezes may be observed during gameplay
[84112] Frame Rate Target Control (FRTC) setting do not apply consistently to all games. In order for FRTC to function properly, Vertical Refresh/VSync must be turned off
[58978] DiRT Rally – A crash may occur when starting a new race with AMD Crossfire™ and AMD FreeSync™ enabled
[83370] The AMD Gaming Evolved overlay may cause a black screen, or introduce game stutter
[82497] Assassins Creed Syndicate - Using "Very High" graphics settings in 3x1 Eyefinity mode may cause displays to switch off
[82093] Star Wars™: Battlefront - Some flickering may be experienced in shaded areas of the screen while game levels are loading
[82788] Call of Duty: Black Ops 3 - Frame freezing during gameplay may be experienced
[82794] Just Cause 3 - The system may hang when task switching on systems with AMD CPUs and GPUs
[82777] Just Cause 3 - Application profile setting added for laptops with Switchable Graphics
[82779] Fallout 4 - Gameplay may be choppy in AMD FreeSync™ mode in Ultra mode at 1440p resolution
[82895] Fallout 4 - Brightness flickering observed with AMD FreeSync™ enabled on certain displays
[80254] cnext.exe intermittently crashes during Windows® shutdown
[81809] A crash may be experienced if an HDMI™ display is a cloned display device on an HP Envy 15 notebook
[82485] "Failed to create OpenGL context" error message may appear after installation
[82842] "Cannot find RadeonSettings.exe" error message may appear during installation
[83277] "AMD Install Manager has stopped working" error message may appear during installation
[83484] "Cannot find cncmd.exe" error message may appear during installation
[82902] Display may flicker on certain laptops after prolonged gameplay with AMD FreeSync™ enabled
[81489] Unable to create 4x1 or 2x1 portrait mode SLS with 4K displays
[82042] Video corruption may appear in Movies & TV app when is VSR enabled and scaling mode is set to "Full panel"
[82492] Portrait Eyefinity mode may not be configured correctly using Radeon Additional Settings
[82695] No display on certain laptops when toggling display mode or connecting an HDMI™ display
[82900]/[81859] Flickering may be experienced on some monitors when AMD FreeSync™ is enabled
[80064] Notifications reverting back to English on non-English systems after reboot
[82490] Misaligned UI may be observed on the Bezel Compensation screen
[81777] Launching a game from the Game Manager may launch on a single display after enabling and disabling AMD CrossFire™ in a 3x1 AMD Eyefinity™ setup
[81856] Marginally increased power consumption may be observed during video playback
Known Issues
[79428] StarCraft II: Flickering may be observed in the 'Episode 3' campaign
[80836]/[59701] Call of Duty: Black Ops 3 - Flickering or poor performance may be experienced when running in AMD Crossfire™ mode
[81736] Call of Duty Online - The game may crash if the Print Screen key is pressed on a 4K monitor
[81448]/[77961] A system restart may be experience when waking the system from sleep mode on some systems with Intel processors
[81651] Star Wars™: Battlefront - Texture corruption may be experienced if the game "Field of View" setting is > 100
[82213] Star Wars™: Battlefront - Some users may experience minor flickering or corruption at different game location or while viewing the in-game cinematics
[81915] Assassin's Creed Syndicate - Building textures may be missing on some AMD Freesync™ displays with VSync enabled
[82387] Assassin's Creed Syndicate - The game may crash if the Gaming Evolved "In Game Overlay" is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay"
[82789] Total War™: Rome II - Choppy gameplay may be experienced
[84509] Gaming Evolved client does not initiate when launching Metro Last Light if AMD CrossFire™ is enabled
[84434] Far Cry 4 – A crash may occur after performing (ALT + Enter) to switch between windowed/full screen modes with the AMD Gaming Evolved "Video Capture" feature turned on
[82499] Talos Principle - A crash may occur while changing Gaming Evolved Video settings or pressing ALT + Enter when "In Game Overlay" is enabled
[84591] Mad Max – Low FPS performance may be experienced in game when AMD FreeSync™ and AMD CrossFire™ are enabled
[84428] Battlefield Hardline – A crash may occur when changing graphics settings from "Ultra" to "High" during gameplay
[83839] Some games may experience brightness flickering with AMD FreeSync™ enabled
[83833] Radeon Settings - AMD OverDrive™ clock gauge needles for the secondary GPU may be in wrong position when the system is idle and the secondary GPU is inactive
[83832] Radeon Settings – AMD OverDrive™ Power setting changes on the secondary GPU are not immediately displayed. This is seen only on dual GPU graphics cards, such as the AMD Radeon™ HD 7990 and Radeon R9 295x2
[83287] Game stuttering may be experienced when running two AMD Radeon™ R9 295X2 graphics cards in AMD CrossFire™ mode
[82892] Display corruption may occur on multiple display systems when it has been running idle for some time
[83031] Star Wars™: Battlefront – Corrupted ground textures may be observed in the Survival of Hoth mission
[82824] Call of Duty: Black Ops 3 – Flickering may be observed is task switching is used during gameplay
[81915] Assassin's Creed Syndicate – Building textures are missing and game objects stutter if VSync is enabled in Quad AMD Crossfire configurations
Resolved Issues
Known Issues
Unbekannter Krieger
- 4x4 GiB Hynix DDR3-1866 ECC
- TSST SH-222AL
- Win8.x x64, Win7 x64
Welchen dringlichen oder schweren Fehler behebt der Treiber denn, dass er die Bezeichnung Hotfix verdient? Mir scheinen es allgemeine Fehlerbehebungen zu sein, die aufgeführt werden.
Hatte AMD nicht angekündigt 2016 mehr Treiber rauszubringen mit der Unterscheidung zwischen Release und Hotfix - ansonsten gibt es ja noch so einiges zu "fixen" im Crimson.
Psychodelik
- Intel Core i7-3770 K
- Gigabyte GA-Z77X-UD5H
- top-blow Kühler inkl. 2 x 140 mm Lüfter
- G-skill 2 x 8 GB RAM
- Sapphire R9-390 NITRO with backplate, 8GB RAM
- HP ZR2440w
- Samsung SSD 830 Series
- Samsung HD240 UI
- LG Blue-Ray Brenner, LG DVD Brenner
- Creative Sound Blaster ZxR
- Enermax 750 Watt Netzteil inkl. Kabelmanagement
- Microsoft Windows 10 Pro x64 Edition
- Firefox, Vivaldi
... gerade eben habe ich die integrierte Update Funktion der Crimson Edition angeworfen und siehe da, es steht ein neue WHQL Treiber zur Verfügung. Die Nummer des Treibers lautet 16.15.0000.0000 - 160105a.
Wenn ich aber auf die Versionshinweise drauf klicke, lande ich bei Version 15.12 WHQL.
Was ist dran an dieser Meldung ?
Ist es ein Fehler seitens AMD oder wie darf ich die ganze Angelegenheit verstehen ?
Kann mal einer bitte kurz selber bei seinem Crimson Edition die Update Funktion anschmeissen und schauen ?
Nosyboy
- Switzerland
- LENOVO Y520-15, Intel i7-7700HQ, W10-Home
- Ryzen 7 5700X / 7nm / 65W
- Sapphire Radeon RX5700 PULSE 8G
- Samsung C27FG70
- Pioneer BDR-209M
- on Board
- Chieftec Midi Tower
- Corsair RM550x
- Logitech G213
- WIN 10 Pro
- Opera / Edge
- ▼100 MBit ▲20 MBit
Ja, nach dem Update steht immer noch 15.30, wurde anderswo schon bestätigt.
https://www.reddit.com/r/Amd/comments/40ny7d/crimson_driver_not_updating_to_1615/
Unbekannter Krieger
- TSST SH-222AL
@Psychodelik
Lass dich nicht kirre machen. Überleg, was du installiertest. War es 16.1 Hotfix? Ja? Dann ist alles bestens.
Internen Update-Funktionen sollte man nie trauen. Erhält man von einer eine andere Information als aus einer anderen Quelle, so hat Erstere mit hoher Wahrscheinlichkeit Unrecht. Deshalb mag ich interne "Updater", die nur den Browser für dich öffnen und die Seite aufrufen, auf der man die neueste Version (oder seine installierte der neuesten gegenübergestellt) sieht.
Und dass ein Grafiktreiber mal die Versionsnummer einer älteren Version zur Schau stellt, passiert fast jedes Jahr.
SPINA
- AMD Ryzen 7 3700X
- ASUS PRIME X370-PRO
- AMD Wraith Prism
- LG Electronics 27UD58P-B
- HL Data Storage BH16NS55
- Lian Li PC-7NB
- Seasonic PRIME Gold 650W
- Debian 12.x (x86-64)
- ASUS TPM-M R2.0
Oi!Olli
- HP Elitebook 8760W
- Ryzen R7 5800X3D
- Asus B 550 Strix F Wifi
- Acer Predator XB253QGP
- GH-22NS50
- Soundblaster Recon 3d
- Raijintek Zofos Evo Silent
Nö, denn ich hab kein Linux.
SPINA
- AMD Ryzen 7 3700X
- AMD Wraith Prism
- Lian Li PC-7NB
- ASUS TPM-M R2.0
Das ist keine GNOME/KDE Meldung, sondern eine von Windows 10 Pro (Build 10586 - AMD64).Nö, denn ich hab kein Linux.
