Download ATI Catalyst 9.11
- Ersteller cruger
ATI hat sein CATALYST Grafikkarten- und Chipsatz-Treiberpaket in der Version 9.11 für Windows XP, Vista und 7 zum Download freigegeben. Voraussetzung für das CATALYST Control Center ist unter Windows XP ein installiertes Microsoft .NET Framework. Eine aktuelle Version des .NET Framework kann man über die Microsoft Windows Update Seite beziehen.
<blockquote><b><font size="3">New Features</font></b>
This section provides information on new features found in this release of the Radeon™ Display Driver. These include the following:
<ul><li><i>GPU Acceleration of H.264 video content using Adobe Flash Player 10.1 Beta</i></li><li><i>High Quality downscaling for video transcoding MSE</i></li></ul>
<b>GPU Acceleration of H.264 video content using Adobe Flash Player 10.1 Beta</b>
<blockquote>This release of ATI Catalyst™ supports the new Hardware Acceleration features of Adobe Flash Player 10.1 Beta for video encoded in the H.264 format. Adobe Flash Player 10.1 Beta introduces hardware-based H.264 video decoding to deliver smooth video playback, reduce system resource utilization, and preserve battery life. Adobe Flash Player 10.1 Beta is expected to be available for download from Adobe Labs (labs.adobe.com) before the end of the year. This feature is supported on the ATI Radeon HD 5800, ATI Radeon HD 5700 and ATI Radeon HD 4000 Series of products.</blockquote><b>High Quality downscaling for video transcoding MSE</b>
<blockquote>This release of ATI Catalyst™ includes an enhancement for the ATI Video converter for users transcoding high quality interlaced content (1920x1080i @60i videos) down to small resolution progressive content (320x240 @30p - iPod videos as an example), by maintaining high visual quality when down-scaling by a significant amount and converting interlaced video content to progressive.</blockquote></blockquote>
Die Download-Links führen zu den Game.AMD.com Support-Seiten, wo man die Treiberpakete einzeln (Windows XP) oder aber komplett (Windows XP & Vista) inkl. CATALYST Control Center beziehen kann.
<b>Download:</b><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-32-components" target="b">ATI Catalyst 9.11 Display Driver [Windows 7 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-64-components" target="b">ATI Catalyst 9.11 Display Driver [Windows 7 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/vista32-components" target="b">ATI Catalyst 9.11 Display Driver [Windows Vista 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/vista64-components" target="b">ATI Catalyst 9.11 Display Driver [Windows Vista 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/xp32-components" target="b">ATI Catalyst 9.11 Display Driver [Windows XP 32-Bit / MCE]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/xp64-components" target="b">ATI Catalyst 9.11 Display Driver [Windows XP 64-Bit]</a></li></ul><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/mobility-xp" target="b">ATI Catalyst 9.11 Mobility Kompatibilitätsprüfung</a></li></ul><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=Integrated/vista32-chipset" target="b">ATI Catalyst 9.11 Chipset Southbridge/AHCI/Raid Tool [Windows 7 & Vista]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=Integrated/xp32-chipset" target="b">ATI Catalyst 9.11 Chipset Southbridge/AHCI/Raid Tool [Windows XP]</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://www2.ati.com/relnotes/Catalyst_911_release_notes.pdf" target="b">Release Notes Catalyst 9.11</a></li><li><a href="http://www.microsoft.com/downloads/details.aspx?familyid=AB99342F-5D1A-413D-8319-81DA479AB0D7&displaylang=de" target="b">Microsoft .NET Framework 3.5 SP1</a></li></ul>
Cimex
- IBM Thinkpad T41p
- Phenom 9850 BE
- Asrock AOD790GX
- Noctua NH-U12P
- 4 GB Aeneon Xtune 1066
- Radeon 3870
- Iiyama E481S
- WD6400AAKS
- Pioneer DVR-215
- Zirco AX
- Enermax Modu82+ 425W
- Vista64 Ultimate SP1
- Technisat CableStar HD 2
Hatte ja eigentlich auf einen fix für Dragon Age gehofft. Radeon 3870 Karten müssen bei vielen Nutzern aum 100 Mhz auf 700 Mhz untertaktet werden, sonst gibt es Abstürze.
Dr@
- Baden-Württemberg
- Collatz Conjecture
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
hier gibt's den nötigen Player: Adobe Flash Player 10.1 prerelease
In der Pressemitteilunge wurden die IGPs der 3000er Serie auch erwähnt. Warum werden die hier (in den Release Notes) nicht mit aufgeführt?
Avivo converter & CCC sind beim dl (mom) v9.10. "bzgl. vista/win7"
Mit dl zB per FDM, und Anpassung der URL bekommt man diese auch in v9.11. (9-11_vista_win7_32-64_xcode & 9-11_vista32-64_ccc_lang2)
klein van
- Raum Hessen
- Spinhenge@home
- Spinhenge
- i7-860, Q6600, Q6600, E6600, T7400, Athlon4000, i5-560M
- Lenovo R60
- Intel i7-860
- GA-P55A-UD6
- Noctua P12 mit 2x120/35
- 2x2GB DDR3 1600 OCZ
- ATI HD6850
- 19 TFT
- 1xWDC15 als System; 2x500er Samsung
- GGC-H20L, LG GSA-H55N
- Chieftec Mesh LCX-01BL-BL-B, blau
- Enermax 485W Noisetaker (EG495AX-VE(W)-SFMA)
- Windows7 Ultimate 64 bit
- IE8, FireFox3.6xx
http://www.computerbase.de/downloads/treiber/grafikkarten/ati/ati_catalyst_control_center/
für XP bis Win7
ist in deutsch, aber bisher nur der Cat. Avivo kommt wohl später
für XP bis Win7
Bobo_Oberon
Adobe beschreibt das in der eigenen Doku ... 3000`IGPs ja, 3000`Grafikkarten Nein?!Bin gespannt ob das mit den 3000er IGP Chips auch geht. Wäre SEHR wünschenswert. Immerhin sind die schön verbreitet und müssten auch nen universal Video Decoder haben.
Hatte dazu auch einen Kommentar in der Pressemeldung geschrieben.
MFG Bobo(2009)
Exfreeman
- Oldenburg in Niedersachsen
- Phenom II 920@3004Mhz
- Asrock A770 Crossfire
- Standard Boxed
- 4GB Kit OCZ PC8500 5-5-5-18
- XFX Radeon HD 5870
- 28" Hans G 1920 x 1200
- Seag.Barracuda ST3500410AS
- LG DVD-Brenner
- Soundblaster X-fi extreme Music
- Coolermaster Storm
- Skythe Plugin 750 Watt
- Windows 7 64 Bit
Nach der Installation des USB-Filter-Treibers ging bei mir nicht ein USB-Gerät mehr !
Nur eine Systemwiederherstellung mittels PS2-Tastatur hat dies wieder behoben. Es reichte nicht, die Ati-Software komplett zu entfernen...
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
MFG Bobo(2009)
Bleibt aber trotzdem die Frage, warum es in den Release Notes des Treibers nicht steht!
Bobo_Oberon
Frage nicht mich ... frage AMD/ATI ...Bleibt aber trotzdem die Frage, warum es in den Release Notes des Treibers nicht steht!
Beerman
Evtl. auch für einige interessant:
Obwohl ich irgendwo gelesen hatte, das es eher ein Fehler von dem Spiel wäre...
Ich kann es leider nicht testen, hab kein Vista und auch kein ANNO 1404
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
- ANNO 1404 (also known as "Dawn of Discovery") no longer displays black texture corruption instead of surface terrain for some ASICs
Stami
GOTTSEIDANK! auch endlich für uns "legacy"-Nutzer.
Hoffentlich diesmal aber wirklich ein echter 9.11er denn der 9.8er legacy war definitiv ein 9.3er!
http://support.amd.com/us/gpudownloa...3&lang=English
Stami
Stami
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
Stami
Dein Link funkt bei mir nicht!
Hier die Links zum 9.11er Legacy:
Windows XP - Professional/Home; Windows XP Media Center Edition
Windows Vista - 32-Bit Edition
Windows Vista - 64-Bit Edition
Release Notes (wurde nicht aktualisiert!)
AMD schrieb:Note: AMD’s DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration
MfG @
AMD_Baer
- Weltbewohner
- Notebook?? Was soll ich mit nem Frauen Computer?
- AMD FX 6350 Black Edition
- ASUS M5A97 R2.0
- Arctic Cooling Freezer 64
- Crucial Technology 1866Mhz 2x4096MB / 9-9-9-27
- Powercolor Radeon HD6870 1GB
- Asus 22Zoll
- Samsung 840EVO 250GB
- Samsung DVD Brenner SATA
- Realtek onboard
- Coolermaster Midi Tower
- be Quiet Dark Power PRO 550 Watt
- Windows 7 Home Premium 64bit
- Google Chrome
- System im schleichenden Umbau begriffen.
Das gleiche bei mir, Habe Win7 Home Premium 64bit und nach der Installation ging kein einziger USB Anschluß mehr, musste es auch per PS/2 Tastatur und Systemwiederherstellung beheben. Finger weg momentan vom SB Treiber.
Tardiv
- AMD Athlon X2 5400+ (Brisbane) AM2
- Gigabyte GA-MA78GM-S2H
- EKL Großclockner
- 2x Samsung 2GB DDR2 6400
- Eizo L 568
- Samsung HD250HJ
- Asus DRW-2014S1T, Toshiba SD-M1712
- Casetek CS-1026b
- Enermax PRO82+ 385W
- Windows XP
- http://ftp.mozilla.org/pub/mozilla.org/seamonkey/nightly/latest-comm-central-trunk/
- Pfft.
Bei mir scheitert die Installation des Catalyst 9.11 leider unter Windows XP ohne nennenswerte Fehlermeldung. Das ist wohl das bereits im Catalyst Forum beschriebene Problem, dass die Installation nicht funktioniert, wenn man ein neueres C++ SDK als das Win 2005 SDK installiert hat.
Saublöd, aber ich habe jetzt eigentlich keine Lust extra deshalb mein System in einen Zustand zu bringen, in dem der Catalyst 9.11 installiert werden kann, zumal ich das Win 2008 SDK eigentlich auch ab und an brauche.
Bringt der Catalyst 9.11 wirklich merkbare Verbesserungen gegenüber dem 9.10, oder kann man den getrost auslassen, und hoffen, dass das Problem wie angedeutet im 9.12 behoben ist?
Bobo_Oberon
Weils offenbar wirklich nicht für die ATI 3200/3300 als integrierten Chipsätze gilt.hier gibt's den nötigen Player: Adobe Flash Player 10.1 prerelease
Hatte das nun in der Praxis verglichen:
Der neue 9.11-Treiber ist für Überraschungen gut
Im Vergleich zur Flash-Auslastung mit circa 30 Prozent scheints bei Blu-ray zu stimmen, da gibt es H264-Beschleunigung auf der runden blauen Schaube (mit der ATI 3300) ...
Dort habe ich eine Auslastung von maximal 12 Prozent ... ABER seitdem ist ein hübscher roter Streifen auf dem Screen im Abspielfenster der Cyberlink PowerDVD-Software ...
Und weils noch hübscher ist der Bildaufbau mit Blu-ray seitdem etwas ruckeling ... aber womöglich liegts doch an der IGP. Zuvor hatte ich immer nur meine Steckkarte mit dem RV740 (ATI Radeon HD 4770) zum Betrachten von HD-Medien genutzt. Da war kein Ruckeln und Framedrop zu bemerken.
Edit: Mit der "richtigen" Grafikkarte ATI Radeon HD 4770 ist die Last (Flash-Film ist im Cache) auf etwa 16 bis 20 Prozent gesunken. Also scheint UVD1 irgendwo keine Berücksichtigung (Adobe Flash/AMD ATI Treiber) gefunden zu haben.
Edit2: Und natürlich ist KEIN roter Streifen bei der HD-Widergabe zu sehen. UND natürlich ist kein Ruckeln (no shudder) bei den blauen Scheiben zu sehen, bei einer Blu-ray-Last von circa 7 bis 10 Prozent ... so solls sein.
Fazit: Bloss nicht den 9.11-Treiber auf eine 3200/3300 installieren, wenn man Cyberlink PowerDVD 7 als Blu-ray-Player nutzt ... und für Flash ists zur Zeit auch noch sinnbefreit.
MFG Bobo(2009)
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
Damit wird die Sache aber reichlich witzlos!
Ne Beschleunigung von Flash macht doch eigentlich nur auf untermotorisierten Systemen mit IGP Sinn. Alles andere ist eh schnell genug.
Kann jemand mit dem AMD785 testen? Da ist ja eine HD 4200 verbaut. Mit der sollte es dann ja funktionieren.
Hat wohl mal wieder was mit der Unterstützung von Compute Shader zu tun.
UVD2 muss verbaut sein
Crashtest
- Leipzig
- Collatz, yoyo, radac
- yoyo
- Lenovo IdeaPad 5 14ALC05
- Ryzen 7950X / Ryzen 4750G
- ASRock B650M PGRT / X570D4U
- 27" Samsung LF27T450F
- KINGSTON SNVS2000G
- onboard HD?
- zu kleines für die GPU
- CHERRY SECURE BOARD 1.0
- Logitech RX250
- Windows 10 19045.4355 / Server 20348.2402
- Edge 124.0.2478.51
- U320 SCSI-Controller !!!!
- ▼1000 MBit ▲82 MBit
Naja für alle XP/Srv03/XP64/Srv03x64 User die ggf. etwas mehr Performance (bis 30% in einigen neuen Titeln) wollen - kann ich die 9.12 Beta/RC empf. http://www.planet3dnow.de/vbulletin/showthread.php?t=371695
es fehlt "nur" noch's WHQL Logo - dauert etwa 2-3 Wochen ...
die Vista / Srv08 / 7 / Srv08r2 haben noch nicht den Weg ins freie Netz gefunden ...
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
Des Rätsels Lösung steht bei heise:
MfG @
QuelleMit dem AMD-Grafikkartentreiber Catalyst 9.11 funktionieren nun auch die kürzlich vorgestellten Mittelklassegrafikkarten Radeon HD 5770 und HD 5750. Zudem unterstützt er die GPU-Beschleunigung von H.264-Videos via Adobes kürzlich veröffentlichter Betaversion von Flash 10.1. Catalyst-Treiberentwickler Terry Makedon äußerte sich gegenüber heise online, dass dafür exklusiv die UVD-Videoeinheit genutzt wird – und nicht wie teilweise behauptet die Stream-Prozessoren. Daher ist eine Grafikkarte ab der HD-4000er-Serie mit UVD(2)-Videoeinheit erforderlich.
MfG @
Bobo_Oberon
Ist nicht vollends überzeugend, weil die UVD-Einheit schon länger zum Inventar gehört (Xilleon-Kern). Das war nie eine Beschleunigung über die Spiele-Shader.
Aber womöglich spielt es eine Rolle, dass eben jenes besagtes Xilleon-IP gar nicht mehr in AMDs Hand ist, sondern seit geraumer Zeit bei Broadcom ist.
MFG Bobo(2009)
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
MFG Bobo(2009)
UVD2
PuckPoltergeist
MFG Bobo(2009)
Siehe Beitrag von Dr@, UVD gibts seit der r6xx Serie (Ausnahme ist der R600). Für UVD2 braucht es schon r7xx. Ist auch das Problem mit der Beschleunigung unter Linux. Da gibts jetzt nen VA-API Aufsatz für XvBA (allerdings Closed Source), welcher aber auch UVD2 voraussetzt.
Bobo_Oberon
Ja und? Hast du den Wikipedia-Eintrag auch betrachtet?
Da wird UVD als Oberbegriff verwendet und listet dann die verschiedenen Versionen auf. Was bleibt, dass es eine eigenständige Multimedia-Hardware-Einheit, mit spezieller Schnittstelle ist. Und das gilt sowohl für UVD, UVD+, UVD2, UVD2.x.
Die Begründung von Heise spricht etwas an, was gar nicht den Kern trifft. Schon UVD1 war eben nicht eine Beschleunigung über die 3D-Shader der DirectX-10 GPU, sondern siehe oben, eine völlig eigenständige Einheit.
Und offenbar gibt es da Grenzen, die nicht so ohne weiteres Überschritten werden können. Sei es nun lizenzrechtlich, oder aus programmtechnischen Gründen.
MFG Bobo(2009)
