- Foren
- Planet 3DNow! Community
- Astronomie und Astrophysik
- Einstein@Home
Client Fragen ? Lifemapper als Service
- Ersteller strike41
Sir Ulli
- Bad Oeynhausen
- Seti, Spinhenge
- Seti, Spinhenge, ich war vor Ort
- Athlon64 X2 4.400, Imhell Quad 6.600
- HP 530
- Imhell Quad 6.600 at 3.240 8 x 405
- Aus P5K Rev 2.1
- Thermalright SI-128 SE Papst 120 at 1.200
- 2 x A-DATA 4 GB DDR2-800 Kit 4,4,4,12
- Asus 8.500 GT SILENT/HTP/256M
- Samsung SyncMaster 2232BW 22 Zoll TFT
- Western Digital WD10EACS 1 TB
- Samsung SH-S203P Sata
- CS601 mit 2extra Päpsten at 9 Volt
- Fortron 350 Watt
- Windows7 Home Premium
am einfachsten ist es wenn du Lifemapper als Service laufen lässt,
die letzten Lifemapper CLI zum download
Lifemapper 1.0.0.2 Beta für Windows
Lifemapper 1.0.0.2 Beta für Linux
aus den FAQ von TPR
MFG
Sir Ulli
Running the LifeMapper CLI Client as a Service in Windows NT/2000/XP
There are several reasons that you might want to run the LifeMapper CLI as a Windows service, rather than as a normal application. The most obvious is that it gets rid of the taskbar button, reducing clutter. The second is if you prefer, for whatever reason, to run the client in "stealth" mode, i.e., not visible to casual viewers. The final and possibly most useful reason is that when the LifeMapper CLI is running as a service, you are no longer required to be logged in to the machine for the LifeMapper CLI to run. This means that if something causes the machine to reboot, the LifeMapper CLI will resume processing even sitting at the Windows login screen. The following takes you through the process of setting up the LifeMapper CLI client to run as a Windows service.
This procedure makes a couple of fundamental assumptions. First of all, it assumes that you have already installed and configured the LifeMapper CLI(text-based) console client. If not, a trip to the LifeMapper web site will get you started. Secondly, it assumes that the path to the client is "C:\lifemapper\". If you have the LifeMapper CLI installed in a different directory, modify the instructions accordingly.
In addition to your LifeMapper CLI installation which is assumed to be installed in c:\lifemapper\, you will need the two small Microsoft programs in order to set up your service. Instsrv.exe is the program used to create a Windows service, and Srvany.exe is a program that allows almost any other program to run as a service. These files are available in Microsoft's Windows Resource Kit, at various internet sites, or you can just download them both here .
Step 1.
Put Instsrv.exe and Srvany.exe in your LifeMapper CLI directory.
Step 2.
From the Start button, go to Programs->Accessories, then click on Command Prompt. This will open a command window, where you'll need to change to your LifeMapper directory by typing cd\lifemapper, then pressing ENTER.
Step 3.
Type instsrv LifeMapper c:\lifemapper\srvany.exe and press ENTER. This will create a service called "LifeMapper". You can substitute a different service name if you wish. If the process is successful, you'll see the following message:
code:
CreateService SUCCESS at creating:
LifeMapper
You must now go to the Registry and the Services applet in the
Control Panel and edit them as per the instructions.
When you're done, just minimize the command window, as we'll be returning to it later in the process.
Step 4.
Open Regedit by clicking Start->Run, then typing regedit and pressing ENTER.
Step 5.
Navigate to the following registry key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\LifeMapper
Step 6.
In the left pane of the registry window, click on the LifeMapper key. Then, in the right pane, right-click and choose NEW -> KEY. Name the key Parameters
Step 7.
In the newly-created Parameters key, right-click and choose NEW -> STRING VALUE. Name the value AppDirectory
Step 8.
Repeat Step 7 to create a second new string value. Name it Application
Step 9.
Repeat Step 7 to create a third new string value. Name it AppParameters
Step 10.
Double-click on the String Value "AppDirectory". This will bring up the Modify dialog box. Set the value for AppDirectory to c:\lifemapper\
Step 11.
Double-click on the String Value "Application" Set the value for Application to c:\lifemapper\lifemapper_cmd.exe
Step 12.
Double-click on the String Value "AppParameters" Set the value for Application to -q -e <your LifeMapper email address> -p 64
(NOTE: The above sets the client to quiet mode, with a low/idle priority. Feel free to add/change the options as you see fit. Just look at the readme.txt file included with the LifeMapper CLI for available options.)
Step 13.
Close Regedit
Step 14.
Stop your existing LifeMapper client(if it is running)
Step 15.
Return to the command window and type net start lifemapper, then press ENTER. If everything is configured correctly, you should see a message indicating that the LifeMapper service was started successfully. If you encounter any errors, the most common causes are that there is either a missing file, or one of the paths was entered incorrectly.
The newly-created LifeMapper service will now function as it always has in terms of processing, uploading, and downloading, and any monitoring software will continue to work normally.
If for any reason you should decide you want to remove the LifeMapper service, go to Control Panel->Administrative Tools->Services. Right-click on the LifeMapper service and choose STOP. After the service is stopped, open a command-prompt window, navigate to your folding directory, and type instsrv LifeMapper remove. This will completely remove the service from your system. You can still run your LifeMapper client as you did before, as a normal application.
Once the Lifemapper CLI is running as a service (using the instructions above) you may want to have an easy way to monitor the progressing WUs.
Monitoring Lifemapper CLI recipe - delicious! (approximately 15 mins in a pre-heated oven)
1. Download CoolMon (takes you to the d/l page, not the file).
2. Get CoolMon all set up and running (I'm not going into this, there are plenty of help files on their site, figure it out for yourself)! Once configured as you wish go to next step!
3. Right-Click the CoolMon icon in the system tray, and select "Display Items"
4. Add the following code to your CoolMon configuration pane:
code:
<U>LifeMapper</U>
Species: <NAME=FILEDATA FORMAT="C:\lifemapper\processing.txt,8,23">
Name: <NAME=FILEDATA FORMAT="C:\lifemapper\processing.txt,9,23">
% Complete: <NAME=FILEDATA FORMAT="C:\lifemapper\processing.txt,11,23">
Total WUs: <NAME=FILEDATA FORMAT="C:\lifemapper\processing.txt,7,23">
WUs cached: <NAME=FILEDATA FORMAT="C:\lifemapper\processing.txt,13,23">
Results cached: <NAME=FILEDATA FORMAT="C:\lifemapper\processing.txt,14,23">
5. Providing the Lifemapper CLI is installed in C:\lifemapper\ then this should work. Modify colors/styles as you wish (again, see CoolMon help files for this info).
6. Lastly, enjoy!
aus den FAQ von TPR
MFG
Sir Ulli
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
Hab das ganze mal als Batch mit reg Datei fuer die Importierung der Registry Schluessel zusammengefasst, das ganze scheint auch zu funktionieren, allerdings macht der Lifemapper Server mal wieder zicken und behindert ein richtiges Testen der Funktion, wenn die korrekte Funktion sichergestellt ist, werde ich das ganze zum Download bereitstellen. Man muss dann nur noch die E-Mail Adresse des Accounts eintragen, ansonsten laeuft das alles automatisch.
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
So Ray hat das gerade noch unter WinXP getestet und es laeuft.
So wer das Ganze mal testen will, wie immer auf eigenes Risiko
Install_LM_dienst
die Dateien nach c:\lifemapperdienst (WICHTIG! nur in dieses Verzeichnis fuer ein Anderes Verzeichnis muessen die Dateien angepasst werden, Erklaerung dazu weiter unten) entpacken und die lm.reg bearbeiten, dort wo email steht die E-Mail Adresse des Accounts eintragen.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Lifemapper\Parameters]
"AppParameters"="-e email"
nur email ersetzen das -e muss stehenbleiben
Danach install_lm_dienst.bat ausführen und neu starten.
Das ganze ist natuerlich nicht fuer Win9x Systeme.
Unter den Diensten in der Verwaltung sollte nun Lifemapper als Dienst auftauchen. Unter Eigenschaften/Anmelden/Datenaustausch zwischen Dienst und Desktop zulassen kann man das Verstecken des Client Fensters rueckgaengig machen. Einfach Haken wegnehmen und Dienst beenden und den Dienst neu starten.
Zum Anpassen der Verzeichnisse:
- Dateien des Zipfiles in gewuenschtes Verzeichnis entpacken.
- die install_lm_dienst.bat bearbeiten
in der Zeile instsrv LifeMapper c:\lifemapperdienst\srvany.exe Laufwerksbuchstaben und Verzeichnis anpassen.
- die lm.reg bearbeiten
"AppDirectory"="c:\\lifemapperdienst\\"
"Application"="c:\\lifemapperdienst\\lifemapper_cmd.exe"
jeweils die Laufwerksbuchstaben und Verzeichnisse bei den ersten beiden Schluesseln anpassen. Unbedingt auf den doppelten \ achten!!!
Bitte um Feedback, obs wie gewuenscht laeuft.
Install_LM_dienst
Sir Ulli
- Bad Oeynhausen
- Seti, Spinhenge
- HP 530
- Aus P5K Rev 2.1
- Fortron 350 Watt
Danke für deine Mühe, aber der Lifemapper Server hat mal wieder gerade so seine Probleme
morgen noch mal testen, der Client ist der 1.0.0.1 nicht
Der Beta Client kann jetzt auch über die offizielle Lifemapper downgeloadet werden.
MFG
Sir Ulli
MFG
Sir Ulli
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Client ist der 1.0.0.1.
Hab das ganze bei dem Rechner meines Cousins noch mal getestet. *hust*
Funktioniert wunderpraechtig, nach der Installation ist ein Neustart auch nicht notwendig, es reicht in die Diensteverwaltung zu gehen und den Dienst zu starten, beim naechsten Neustart wird der Dienst dann automatisch gestartet.
Ich habe nur bei den AppParameters noch ein -c 10 von Hand eingefuegt.
ICEMAN
- AMD Ryzen 3 2200G
- HP 255 G8
- AMD Ryzen 5 5600G
- MSI B450 Gaming Plus
- Noctua NH-U9F
- AMD Radeon Vega 8
- 1TB Samsung HD103SJ
- DVD-Brenner
- Windows 10 64bit Prof.
▼250
ich habe nun das alles befolgt, was hier geschrieben steht aber es ist immer noch nicht versteckt
Woran kann das liegen?
EDIT:
Hat sich erledigt. War ein kleiner hacken, der sich im Dienst eingeschlichen hat
Coole sache das mit dem CoolMon.
EDIT:
I appreciate the value in having a discussion on the aspects and suggest look at this outlook express reparieren and outlook express troubleshooting . And say what do you think about it....
