Neues Mainboard von Soltek fehlt noch?
- Ersteller Nero24
BlackArchon
- Zwickau
- 2xAMD Opteron 280
- Tyan Tiger K8WE (S2877)
- 2xThermaltake Minityp 90
- 4x1024 MB Infineon DDR333 Registered ECC
- Asus EAX1800 (Radeon X1800XTPE)
- Iiyama Prolite E431S
- WD740ADFD, WD2000JB
- Pleytor PX750A
- SB Audigy 4
- Avance B031
- Tagan TG480-U22
- Windows XP Prof.
Hier gibts leider kein Sonstige...
Soltek SL56G2
BIOS Z4
Gut:
2 MB Onboard Cache
K6-2+/K6-3+ -CPUs laufen problemlos
VIA 686A-Southbridge (bei VIA MVP3 Northbridge!)
Onboard Sound AC97
Zuverlässig, zuverlässig, zuverlässig
Schlecht:
hm, nix?
Das beste, schnellste, problemloseste Super Sockel 7 Board, was ich je gesehen habe. Läuft in meinem Server ca. 15h/Tag. Kein Freeze, schluckt jede Hardware. Was will man mehr?
Soltek SL56G2
BIOS Z4
Gut:
2 MB Onboard Cache
Onboard Sound AC97
Schlecht:
hm, nix?
Estel
hallo
Dieses fehlt noch!!!!
SL-75FRN-R
NVIDIA nForce2 SPP (SYSTEM PLATFORM PROCESSORS) + MCP2 (MEDIA AND COMMUNICATIONS PROCESSORS)
FSB 333/266 MHz
Supports Dual Channel DDR SDRAM @ *400/333/266 MHz
Supports AGP 8X/4X mode
Supports 2 x Ultra ATA 133/100/66
Integrated Promise Serial ATA RAID controller (SL-75FRN-R only)
Supports 1 x Parallel ATA 133 RAID (SL-75FRN-R only)
Supports ABSII
BIOS Vcore, FSB, AGP, DIMM Voltage Setting
Supports USB2.0/1.1
6-channel Audio
Specification
Processor
AMD Socket-462 Athlon XP / Athlon / Duron processor
Chipset
NVIDIA nForce2 (SPP + MCP2)
SPP:
- Features 333/266/200MHz Front Side Bus settings
- Dual Channel *400/333/266MHz Memory Bus
- DDR200, DDR266, DDR333, DDR400 compliant
- Asynchronous Memory Mode
- Supports AGP 8X/4X
* Soltek Computer Inc. typically runs a DDR 400 Memory Module Validation Program. Detailed information is available here.
MCP2:
- Supports Ultra ATA-133/100/66 transfer protocol
- Provides 6-channel AC'97 Audio
- Support for six USB 2.0/1.1 Ports (max.)
Memory
3 x 184-pin DDR DIMM
Supports 6 banks up to 3GB DRAMs for Unbuffered DDR SDRAM Module
Cache Memory
Built-in to AMD Athlon¢â XP, Athlon¢â and Duron¢â Processor Module
On-Board EIDE
2 x PCI Bus Master UATA 133/100/66 IDE ports (up to 4 ATAPI Devices)
Supports for PIO Mode 3, 4, UATA 133/100/66 IDE & ATAPI CD-ROM
1 x PCI Bus Master UATA 133/RAID IDE port by Promise Serial ATA RAID controller
(SL-75FRN-R only)
2 x SATA RAID Interface by Promise Serial ATA controller
(SL-75FRN-R only)
Integrated Super I/O
1 x Floppy Port (supports 360K, 720K, 1.2M, 1.44M and 2.88Mbytes)
2 x serial ports (high-speed 16550A FIFO UART Ports)
1 x Parallel Port with EEP/ECP/SPP Capabilities
1 x PS/2 Mouse, 1 x PS/2 Keyboard connectors
6 x USB Ports (four via optional cable)
1 x Audio/Game Port
Expansion Slots
1 x AGP 8X/4X Slot
5 x 32-bit PCI Bus Master Slots
Form Factor
ATX Form Factor (305mm x 245mm)
BIOS
AWARD Plug-and-Play BIOS
Supports Advanced Power Management Function
Flash Memory for easy upgrade
Other Features
BIOS Multiplier Setting (Optional) ¡Ü RedStorm Overclocking (Optional)
BIOS FSB Setting
BIOS Vcore setting
6-ch AC'97 Audio Function
BIOS AGP Voltage Setting
SmartDoc. Anti-burning Shield
BIOS DIMM Voltage Setting
H/W Monitor
MFG
Aragorn
SL-75FRN-R
FSB 333/266 MHz
Supports ABSII
Supports USB2.0/1.1
6-channel Audio
Specification
Processor
Chipset
SPP:
MCP2:
Memory
Cache Memory
On-Board EIDE
(SL-75FRN-R only)
(SL-75FRN-R only)
1 x Audio/Game Port
Expansion Slots
1 x AGP 8X/4X Slot
Form Factor
BIOS
Other Features
BIOS FSB Setting
BIOS Vcore setting
H/W Monitor
MFG
Aragorn
fallenangel
und das -RL (Raid&Lan). Hat VDD im offiziellen BIOS und halt 1x Parallel und S-ATA-Raid.
K7Jo
Hallo leute ich hab mir dieses BOard gekauft.
Superschnell Auch mit einem 1400 Palomino
Mit dual Channel mit 133 MHz der Absolute Wahnsinn im Vergleich zu einem SIS 735 chipsatz
Das einzige Problem das mir auffällt ist das es Schwierigkeiten mit Radeon Grafikkarten gibt Bei mir spetiell mit Sapphiere
Sonst find ich das Layout gut Und in einem Gehäuse mit Plexiglas sieht es ganz gut aus.
Kann ich nur empfehlen.
Neo
Moderator
- ABI
- AMD Ryzen 7 1800X
- MSI B550-A PRO
- einer mit Lüfter :p
- 2x 8GB Crucial DDR4-2400
- Sapphire R9 270X
- 2x Acer 22" 16:19
- SanDisk SDSSDP128G
- 320GB (Samsung)
- LG-irgendwas
- Realtek ALC887 (OnBoard)
- SeaSonic B12 BC-550
- EDGE
Ist der DB hinzugefügt
