Download RivaTuner 2.22
pipin
Administrator
Teammitglied
16.10.2000
24.371
9.696
East Fishkill, Minga, Xanten
  • SIMAP Race
  • QMC Race
  • RCN Russia
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2019
  • SETI@Home Intel-Race II
  • THOR Challenge 2020
  • BOINC Pentathlon 2021
  • BOINC Pentathlon 2023
Die Version 2.22 des Tweaking-Programms für ATI- und NVIDIA-Grafikkarten ist erschienen und bietet zahlreiche Verbesserungen. RivaTuner bietet Zugriff auf zahlreiche nicht über den GeForce- bzw. Catalyst-Treiber erreichbare Einstellungsmöglichkeiten.
Die aktuelle Version unterstützt die aktuellen Treiber der beiden Hersteller bis zum ForceWare GeForce 181.xx und AMD ATI Catalyst 8.12.
<b>Version 2.22</b>
<blockquote>
<b>Minor bugfixes:</b>
<blockquote>° Fixed bug in LM63.dll plugin, causing empty graphs with no data to be displayed in hardware monitoring module and introduced during porting the plugin to multi-GPU architecture in version 2.20.
° Multifunction PCI devices are no longer scanned and no longer detected as multi-GPU devices.
° Fixed pipeline count detection code for NVIDIA G98 GPU family. </blockquote>
<b>What's new:</b>
<blockquote>° Added ForceWare 181.xx drivers family support.
° Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 180.87, 180.88 and 181.00.
° Updated bundled RivaTunerStatisticsServer v3.0.0 utility:
<blockquote>°° Fully redesigned user interface:
<blockquote>°°° Now the server supports user interface skins to conform requirements of AIB/AIC partners bundling the server with their products. User interface skinning is based upon proprietary engine, which was previously used only in commercical RivaTuner technology based products. User interface skinning usage approach allows RivaTuner fans community to change the server's appearance completely and to express themselves in new skins design. Skin format is completely open, skin compiler and decompiler are integrated in the server, so please visit techsupport forums to get more detailed information and help on the skin creation.
°°° Simplified beginner oriented profile settings. Many previously available power user oriented options, such as per-3D API hooking options, are now merged into more simple multi-buttons, e.g. "Application detection level" multi-button.
°°° Improved help system. Now context sensitive help system is activated by hovering mouse over the control, instead of traditional right-click and "What's this?" based access in the previous versions.
°°° On-Screen Display preview window greatly simplifies realtime On-Screen Display position, color and zoom adjustment. </blockquote>
°° Fully redesigned profiles architecture:
<blockquote>°°° Now pre-created and user profiles are no longer stored into single file, so user profiles are no longer lost after the server reinstallation. Please take a note, that the user profiles are preserved only when the server is reinstalled in the same folder.
°°° Now it is no longer possible to remove critically important pre-created profiles and pre-created profile settings can be easily restored due to template based profiles architecture.
°°° Improved screen capture safety. The server no longer crashes on attempt to capture screenshot in DirectX9 applications without October 2006 or newer DirectX runtime libraries installed.
°°° Improved product customization features:
<blockquote>In addition to skins and previously available product name customization feature, bundling partners can also customize product icon (including system tray icon) and define a link to own online product help page.
°°°° Product customization information is no longer stored in editable text OEM file, now this information is encoded to protect the product from illegal modification and distribution by third parties. </blockquote>
</blockquote></blockquote>
° Improved installer and uninstaller:
<blockquote>Improved installation and uninstallation routines for statistics server's hook libraries.
°° Now the uninstaller also removes the files installed by 64-bit signed driver update
</blockquote></blockquote></blockquote>
<b>Download:</b> <a href="http://downloads.guru3d.com/RivaTuner-v2.22-download-163.html">RivaTuner 2.22</a>
<b>Link zum Thema:</b>
<ul><li><a href="http://www.guru3d.com/index.php?page=rivatuner" target="b">RivaTuner Homepage</a></li></ul>
