Download VirtualBox 3.0.10
- Ersteller KIDH
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- Thermaltake Silent Boost K8
- GeForce 6800 GT
- DVD-ROM / DVD-Brenner
- Creative Audigy
- noname
- Enermax Liberty 400W Dual
- Win98SE / WinXP SP3
Die kostenlose Virtualisierungssoftware VirtualBox wurde in der neuen Version 3.0.10 veröffentlicht.
VirtualBox ist für Windows, Mac OS X, Linux und Solaris verfügbar. Zu den unterstützten Gastsystemen zählen neben Windows, Linux und Solaris auch OS/2, DOS und einige BSD-Derivate.
<b>Changelog:</b>
<blockquote><i>This is a maintenance release. The following items were fixed and/or added:
* VMM: guest SMP stability fixes
* VMM: fixed guru meditation with nested paging and SMP guests (bug #5222)
* VMM: changed VT-x/AMD-V usage to detect other active hypervisors; necessary for e.g. Windows 7 XP compatibility mode (Windows & Mac OS X hosts only; bug #4239)
* VMM: guru meditation during SCO OpenServer installation and reboot (VT-x only; bug #5164)
* VMM: fixed accessed bit handling in certain cases (bug #5248 )
* VMM: fixed VPID flushing (VT-x only)
* VMM: fixed broken nested paging for 64 bits guests on 32 bits hosts (AMD-V only; bug #5285)
* VMM: fixed loading of old saved states/snapshots (bug #3984)
* Mac OS X hosts: fixed memory leaks (bug #5084)
* Mac OS X hosts (Snow Leopard): fixed redraw problem in a dual screen setup (bug #4942)
* Windows hosts: installer updates for Windows 7
* Windows hosts: fixed blue screen when using certain USB devices (bug #5129)
* Solaris hosts: out of memory handled incorrectly (bug #5241)
* Solaris hosts: the previous fix for #5077 broke the DVD host support on Solaris 10 (VBox 3.0.8 regression)
* Linux hosts: fixed module compilation against Linux 2.6.32rc4 and later
* Guest Additions: fixed possible guest OS kernel memory exhaustion
* Guest Additions: fixed stability issues with SMP guests
* Windows Additions: fixed color depth issue with low resolution hosts, netbooks, etc. (bug #4935)
* Windows Additions: fixed NO_MORE_FILES error when saving to shared folders (bug #4106)
* Windows Additions: fixed subdirectory creation on shared folders (bug #4299)
* Linux Additions: sendfile() returned -EOVERFLOW when executed on a shared folder (bug #2921)
* Linux Additions: fixed incorrect disk usage value (non-Windows hosts only)
* Linux installer: register the module sources at DKMS even if the package provides proper modules for the current running kernel
* 3D support: removed invalid OpenGL assertion (bug #5158 )
* Network: fixed the Am79C973 PCNet emulation for QNX (and probably other) guests (bug #3206)
* VMDK: fix handling of split image variants
* VHD: do not delay updating the footer when expanding the image to prevent image inconsistency
* USB: stability fix for some USB 2.0 devices
* GUI: added a search index to the .chm help file
* GUI/Windows hosts: fixed CapsLock handling on French keyboards (bug #2025)
* Shared clipboard/X11 hosts: fixed a crash when clipboard initialisation failed (bug #4987)</i></blockquote><b>Update:</b>
Die Version 3.0.10 wurde kurz nach der Veröffentlichung wieder zurückgezogen. Folgendes Statement wurde veröffentlicht:<blockquote><i>The 3.0.10 binaries that briefly appeared on the web site suffer from a last minute regression that breaks software virtualization (not VT-x nor AMD-V). We've removed all the files and are preparing a new build.
Please downgrade to 3.0.8 or wait till the end of the day for the new version.
Sorry for the inconvenience.</i></blockquote>Wir melden natürlich, wenn es eine überarbeitete Version gibt.
<b>Update 2</b>
Aktualisierte Kompilate sind nun online.
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20091029222331">VirtualBox 3.0.10 [Windows x86/x64]</a></li><li><a href="http://www.virtualbox.org/wiki/Linux_Downloads" target="_blank">VirtualBox 3.0.10 [Linux]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20091029222332">VirtualBox 3.0.10 [Solaris/OpenSolaris]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20091029222333">VirtualBox 3.0.10 [Mac OS X]</a></li></ul>
<b>Changelog:</b>
<b>Update 2</b>
mibo
- Hannover
- Lenovo T450s
- Ryzen 5800X3D
- ASUS B550M-PLUS
- Noctua NH-U12P
- 2x16GB DDR4 ECC
- AMD 6700XT
- HP X27i
- Samsung 860EVO, 960EVO, WD 850X
- DVD-Brenner :-)
- BQ Dark Power 12 750W
Die News sind zu schnell - ich finde die Downloads (der Linux-Link und auf der Vbox Homepage) noch nicht.
Riss im Raum-Zeit-Gefüge?
Maddis
- Athlon X2 (45W)
- 780G / SB700
- Boxed
- 4x DDR2-800
- HD3200 (OnBoard)
- TFT (HDMI)
- SATA
- SATA, USB2.0
- OnBoard
- Midi-Tower
- 80-Plus (Bronze)
- Win7-SP1x64
- Firefox (aktuelle Release Version)
- NIC: OnBoard, TV: PCI-Karte DVB-C (HDTV), USB-Stick DAB/DAB+/DVB-T
mibo
- Hannover
- Lenovo T450s
- Ryzen 5800X3D
- ASUS B550M-PLUS
- Noctua NH-U12P
- 2x16GB DDR4 ECC
- AMD 6700XT
- HP X27i
- DVD-Brenner :-)
Ahh, danke für den Link.
Manchmal ist es vorteilhaft, nicht der Erste zu sein Sonst würde ich jetzt fluchend vorm Rechner sitzen...
Fruchtnektar
Wollte mich gerade deshalb schon beschweren, aber gut, dass andere auch mitdenken und Informationen posten
Maddis
- Athlon X2 (45W)
- 780G / SB700
- Boxed
- 4x DDR2-800
- HD3200 (OnBoard)
- TFT (HDMI)
- SATA
- SATA, USB2.0
- OnBoard
- Midi-Tower
- 80-Plus (Bronze)
- Win7-SP1x64
VirtualBox Version 3.0.10 Binaries & Changelog sind auf virtualbox.org nun wieder online. Mal schauen wie lang der Release diesmal hält?!
Habs grad unter Windows 7 installiert. Irgendwie speichert er mir die Einstellungen nicht. Hab den Standard-Pfad von .VirtualBox auf VirtualBox (also ohne Punkt) geändert und dann ne neue VM erstellt. Nach einem neustart ist das alles wieder weg... Hat das Problem sonst noch wer?
Gruß,
Max
Gruß,
Max
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Danke für die Verwaltung der News während meiner Abwesenheit!
