Winamp 5.12
- Ersteller cruger
Die Entwickler von Nullsoft haben eine neue Version 5.12 des Media-Players Winamp zum Download bereitgestellt.
<b>Changelog:</b><ul><li>New: [in_wm] Windows Media Video support (with DRM)</li><li>New: [in_mp4] Support for HE-AAC MP4/M4A files</li><li>Improved: lots of minor plugin improvements</li><li>Improved: Visualization data calculations</li><li>Improved: Significantly less playlist memory usage</li><li>Improved: more multi-user improvements (almost there!)</li><li>Improved: [installer] setup options, saved settings, codec downloading</li><li>Improved: [gen_ff] optimized skinning engine</li><li>Improved: [out_disk] new features</li><li>Improved: [in_cdda] playback/ripping with sonic engine</li><li>Fixed: freezing when cancelling cd burn</li><li>Fixed: video scaling bug (with modern skin scaling < 100%)</li><li>Fixed: minor installer bugs</li><li>Fixed: freeze when loading classic skin with main window hidden</li><li>Fixed: Visualizations for 24bit and 32bit songs</li><li>Fixed: Advanced Title Formatting with Japanese, Chinese and Korean metadata (thanks mrym)</li><li>Fixed: [in_mp3] raw AAC VBR file seeking and bitrate reporting</li><li>Fixed: [in_mp4] unicode metadata writing</li><li>Fixed: [in_wm/in_dshow] mms:// streaming video playback</li><li>Fixed: [in_cdda] audio cd bitrate display</li><li>Fixed: [in_cdda] Sonic engine on 64bit windows (thanks STanger)</li><li>Fixed: lots of small bugs ...</li><li>Updated: Sonic CD Engine 2.2.50</li><li>Updated: libmp4v2 1.4.1</li><li>Updated: Coding Technology AAC+ Decoder 7.2.0</li></ul>
<b>Download:</b><ul><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20051209100150">Winamp 5.12 Full (5,2 MB)</a></li><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20051209100151">Winamp 5.12 Pro (5,2 MB)</a></li><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20051209100152">Winamp 5.12 lite (0,9 MB)</a></li></ul>
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Zu Beginn der eigentlichen Installation (Kopiervorgang der Dateien) wird bei mir von irgendwo her ein Windows Media Format heruntergeladen.
Was zur Hölle ist das? Warum werde ich nicht danach gefragt?
Anschließend eine Fehlermeldung, weil ich "nur" den Windows Media Player 9 und nicht Version 10 installiert habe.
Aus!
Aus!
ist bei mir nicht der fall. kann aber sein, daß winamp das drm-management des media player 10 nutzen kann/will.
sieht du da die option? => Codecs and system libraries => Download and install (if required)Was zur Hölle ist das? Warum werde ich nicht danach gefragt?
Pizzaesser
- Norden
- Asus UL30A
- E6850
- Gigabyte GA-P35-DS3 2.0
- Arctic Cooling Freezer 7
- 4 GB OCZ DDR2 800
- HD 4850
- LG 1970 HR
- WD 320 GB, WD 250 GB
- Thermaltake BachVx
- Win 7 64
"Next" *klick* "Next" *klick* ...grml scheiss Englisch ... "Next"*klick* "Yes"....
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Okay, dann habe ich das übersehen. Asche über mein Haupt.
Trotzdem - es bleibt ein etwas fader Beigeschmack bei der Sache.
deoroller
Was?
Erst Version 5.12 und ganze 3 Wochen gebraucht, um einen neue Version rauszubringen.
Wenn sie das im Schnitt in einer Woche schaffen, ziehe ich den Hut (und wahrscheinlich einen anderen Mediaplayer vor)
Demnächst wird ein neues Winamp beim PC-Start geladen.
Naja, das war erstmal Luft ablassen.
Ich werde solange bei 5.112 bleiben, bis feststeht, dass das Teil nicht so ein Reinfall wie 5.10 war. Das habe ich auch ausgesessen.
[MTB]JackTheRipper
- Reutlingen
- Folding@Home
- 2x X2 3800+
- HP NC2400
- Samsung SyncMaster 305T
- Antec P180B
Gibt's eigentlich ne gute Alternative zu Winamp?
Eigentlich hab ich nix gegen Winamp, aber mir wäre eine Funktion lieb, die es erlauben würde Dateien aus der Playlist gleich komplett von der Festplatte zu löschen. In Winamp ist das ja leider nur über die Library möglich, oder wurde das jetzt schon auf die Playlists erweitert?
boidsen
- Negnidürtressaw
- DIN-A 5, kariert, ohne Rand
- Brain 2.0
Ich nehm schon seit längerem für (fast) alles den Real Alternative mit dem Mediaplayer Classic - und was der nich kann, dafür gibts ja immer noch den VLC...
gruenmuckel
- Gerry-Weber - Stadt
- Collatz, Milkyway, POEM
- POEM & QMC etwa gleich
- Intel Core i7 6700K
- Asrock Z270 Extreme4
- Creative Recon3D PCIe
- Corsair RM650i
- Windows 7 64 SP1
- Firefox aktuelle Version
Winamp 5.091 up and running stable.
Kommando
- Laptop: Clevo P751ZM (15,6")
- Intel® Core™ i5 4690K @ 4 GHz @ 1 V
- 2x8 GB Hyper X Impact @ 2200-10-11-11-1T
- nVidia GeForce GTX 970M 6 GB @ 1238/3130 MHz
- Dell 2709W (27", 1920x1200)
- Samsung SSD 830 (512 GB)
- 230W
- Windows 10 Professional (64 bit)
- Razer Orochi
[MTB]JackTheRipper;2509119 schrieb:Gibt's eigentlich ne gute Alternative zu Winamp?
Ja das hätte ich auch gerne. Ist das irgendwie (evtl. auch über ein PlugIn) möglich?
MDG
- Sony Vaio Pro 13, Microsoft Surfacebook
- AMD Ryzen 3900X
- ASUS Crosshair VII
- NZXT Kraken X62
- 2x 16GB Crucial Ballistix Sport DDR4 3200MHz
- Nvidia 2080Ti
- Acer XB271HUbmiprz
- 1x 1TB nvme SSD
- 1x WD Blue 3TB
- HDMI
- NZXT S340 Elite
- Corsair RM650X
- ganz toll :)
Bei mir stürzt Winamp imemr ab, wenn ein bestimmtes Lied aus der Playlist gespielt wird.
Sehr merkwürdig.
habe das Lied entfernt, nun läuft alles einwandfrei.
MDG
Sehr merkwürdig.
MDG
skelletor
- Dresden
- einheimische Projekte
- Ryzen 7 5800X3D
- MSI X570-A Pro
- beQuiet DarkRock TF
- AMD Radeon 6900XT
- 1x 4TB WesternDigital Red
- Pioneer BluRay Brenner
- noname
- Seasonic X650 (80+ Gold)
- Swiftpoint Z
- Windows 10 Home 64bit
gegenueber der 5.112 startet winamp jetzt schneller meine ich.
gruss
skell
gruss
skell
- 7K
