Download AMD Radeon™ Software for Linux 18.10
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Radeon™ Software for Linux® 18.10 Highlights
Provides support for Ubuntu 16.04.4 and SLE 12 SP3
Enables Vulkan® 1.1 support - Closed and Open source driver conformant with the Vulkan® 1.1 specification
Known Issues
Hang/Error message/Call Trace observed in dmesg while running Ensight_10.2.2a.
Fatal Error occurred while performing Workbench StoryboardGraphics on Ansys 18.1
Package Contents
AMDGPU All-Open and AMDGPU-Pro Driver
ROCm Platform 1.6 in supported distributions
AMD Radeon™ Product Family Compatibility
Radeon™ Software for Linux® is compatible with the following AMD products.
AMD Product Family Compatibility
Radeon™ RX Vega Series Graphics
Radeon™ Vega Frontier Edition
Radeon™ RX 550/560/570/580 Series Graphics
AMD Radeon™ RX 460/470/480 Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R9 Fury/Fury X/Nano Graphics
AMD Radeon™ R9 380/380X/390/390X Graphics
AMD Radeon™ R9 285/290/290X Graphics
AMD Radeon™ R7 240/250/250X/260/260X/350
AMD Radeon™ HD7700/7800/8500/8600
AMD Radeon™ R9 360 Graphics
AMD Radeon™ R5 340
AMD Radeon™ Pro WX-series
AMD FirePro™ W9100
AMD FirePro™ W8100
AMD FirePro™ W7100
AMD FirePro™ W5100
AMD FirePro™ W4300
AMD FirePro™ W4100
AMD FirePro™ W2100
AMD FirePro™ W600
AMD FirePro™ S-Series
AMD Radeon™ Pro WX 9100
Compatible 64-bit Operating Systems
RedHat Enterprise Linux 7.4
RedHat Enterprise Linux 6.9
CentOS 7.4
CentOS 6.9
Ubuntu 16.04.4
SUSE 12 SP3
Base Feature Support
Supported APIs:
OpenGL 4.5 and GLX 1.4
OpenCL™1.2 (not supported for WX2100 and WX3100)
Vulkan™ 1.1
VDPAU/VAAPI
Basic display features
Basic power management features
Note: AMD does not perform QA validation for S4 (hibernation) function as it is highly platform dependent.
KMS (Kernel Mode Setting) and ADF (Atomic Display Framework) support
GPL compliant kernel module
AMD FirePro™ Features (EDID Management and 30-bit color)
FreeSync support (Please refer to this FAQ for more information)
DirectGMA for OpenGL
Install script and native packages for all supported operating systems
Known Issues
Package Contents
AMD Radeon™ Pro Duo
AMD Radeon™ R5 340
AMD FirePro™ W9100
AMD FirePro™ W8100
AMD FirePro™ W7100
AMD FirePro™ W5100
AMD FirePro™ W4300
AMD FirePro™ W4100
AMD FirePro™ W2100
AMD FirePro™ W600
CentOS 7.4
CentOS 6.9
Ubuntu 16.04.4
SUSE 12 SP3
Supported APIs:
Vulkan™ 1.1
VDPAU/VAAPI
Schade, immer noch kein Support für die aktuellen Version von Ubuntu.
Somit immer noch nicht out-of-the-box Ryzen-kompatibel.
- Ryzen R9 9950X3D
18.04 LTS ist nun ganz neu und dürfte dann auch bald unterstützt werden, Ubuntu 16.04.4 mit seinem Kernel 4.13 dürfte keine Probleme mit Ryzen haben
Auch der 4.10 von 16.04.3 sollte ausreichend sein.
Radeon Software for Linux 18.10 Brings Vulkan 1.1, Ubuntu 16.04.4 / SLE 12 SP3 Support (phoronix)
- PrimeGrid@home
- ASRock 570X Taichi P5.50
@Errate
thx, läuft soweit mit Windows 10 1709.
Beim AVP sind es ~ 120 FPS weniger mit Standard Takt vs. fixe 4.9GHz @ 720p lowest (16x AF).
- Ryzen R9 9950X3D
Im Thread verrutscht?
- PrimeGrid@home
Peet007
- AMD Ryzen 8700G
- MSI Mortar B650
- Wasser
- 32 GB
- IGP
- Philips
- onBoard
- 850 Watt
- Manjaro / Ubuntu
- Epiphany
https://support.amd.com/en-us/download/linux
Treiber für 18.04 ist da, hab ihn sogar bei mir am laufen.
Für Boinc müssen noch Links gesetzt werden. Einstein und PrimeGrid gehen.
Code:
Configuring the Optional ROCm Component
The LLVM_BIN environment variable needs to be set prior to running ROCm applications.
To set it temporarily when running an individual ROCm command, such as clinfo, use:
env LLVM_BIN=/opt/amdgpu-pro/bin /opt/amdgpu-pro/bin/clinfo
To set it permanently for all bash and other sh-like shell users, you can use the following command:
echo 'export LLVM_BIN=/opt/amdgpu-pro/bin' | sudo tee /etc/profile.d/amdgpu-pro.sh
See the Ubuntu Environment Variables Community Help for more information.
To set it permanently for all csh users, you can use the following command:
echo 'setenv LLVM_BIN /opt/amdgpu-pro/bin' | sudo tee /etc/profile.d/amdgpu-pro.csh
"Early Preview" und dazu noch manuelles Herumbasteln?
Da warte ich lieber auf den final release.
Aber gut zu wissen, dann probier ich es bei Gelegenheit mal auf dem HTPC. Entweder mit upgrade auf 16.04.4 oder gleich 18.04
Beim 16.04 war beim Installieren auf dem Ryzen ja das klitzekleine Problem, dass die Version keine SSD gefunden hatte und sich somit gar nicht erst installieren ließ.
Wäre mir ohnehin lieber gewesen, da LTS. Die 17 war ja nur so ein kurzes Zwischending.
Schade dass AMD da nicht beizeiten klar kommuniziert hat, dass sie direkt am 18er Treiber arbeiten.
Ich hatte ja mal nachgefragt und es hieß nur schwammig, dass es irgendwann irgendeinen Treiber für irgendeine Version geben wird - man arbeitet halt an was.
Peet007
- AMD Ryzen 8700G
- MSI Mortar B650
- Wasser
- 32 GB
- IGP
- Philips
- onBoard
- 850 Watt
- Manjaro / Ubuntu
- Epiphany
Das manuelle Herumbasteln musst du bei 16.04 auch machen, sonst läuft da nicht mit Bionc. Ist auch von einer AMD Seite hab es halt nur gepostet.
Hauptsächlich geht es halt um die propritären Sachen die mit dem Treiber nachgeliefert werden. OpenGL läuft ja von Haus aus. OpenCL ist irgendwie in Arbeit, so wie ich es verstanden habe will AMD da eine komplett freie Schnittstelle bereitstellen. Die Boinc Projekte müssen dann erst wider ihre Sachen anpassen. Also Jahre bis vll nie......
Bei Einstein sind es halt 20% mehr Leistung unter Linux gegenüber Windows.
Also bei 16.04.2 kann ich mich an sowas umfangreiches nicht erinnern.
Einbauen, AMDGPUpro installieren, fertig.
- Question
- Question
- 26K
