Download AMD Radeon Software Crimson Edition 16.7.2 WHQL verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Radeon-Software-Crimson-Edition-16.7.2-Release-Notes
Radeon Software Crimson Edition 16.7.2 Highlights
The "compatibility mode" UI toggle was designed to reduce total power with minimal performance impact on AMD Radeon™ RX480 reference boards and has been made available to users in the Global Settings menu of Radeon Settings (first introduced in the previous Radeon Software Crimson Edition 16.7.1 driver). This toggle is in "off" by default.
Support for DOOM (with Vulkan API) – enables performance enhancements through support for Async Compute and Shader Intrinsics.
Important Update
These drivers are now Microsoft WHQL certified
Fixed Issues
In the previous Radeon Software Crimson Edition 16.7.1 driver the "Restore Factory Defaults" option under Preferences of Radeon Settings Software would not set the "Compatibility Mode" UI toggle to its default "OFF" value. This is fixed in the Radeon Software Crimson Edition 16.7.2 driver. The "Restore Factory Defaults" options resets all Radeon Settings to their factory default values.
Known Issues
A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
Radeon™ Pro Duo may experience a black screen in Total War™: Warhammer with the games API set to DirectX®12 and V-Sync enabled.
DiRT™ Rally may experience flickering terrain in some races when the advanced blending option is enabled in the games settings page.
Some Overdrive settings may not appear in Radeon Settings for Radeon™ Fury X when in AMD Crossfire mode.
Dota™2 may crash when using the Vulkan™ API and the user changes resolutions or quality settings.
Battlefield™ 4 may experience crashes when using Mantle. As a work around users are suggested to switch to DirectX®11.
Need for Speed™ may experience flickering on some light sources in AMD Crossfire mode.
Frame Rate Target Control gaming profiles may fail to enable for some games.
Radeon Wattman may retain settings of an overclock after it has failed. If you have failed an overclock with a system hang or reboot make sure to use the "Reset" option in the Radeon WattMan settings page when the system has rebooted.
Low frame rate or stutter may be experienced Wolfenstein®: The Old Blood™ on Radeon™ RX 480.
Assassin's Creed® Syndicate may experience a game crash or hang when in game settings are set to high or greater.
Disabling AMD Crossfire mode on Radeon™ RX 480 may disable the device in Windows® Device Manager. A workaround is to reboot the system to re-enable the device.
Compatible Operating Systems
Radeon Software Crimson Edition 16.7.2 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 (32 & 64-bit version)
Windows® 8.1 (32 & 64-bit version)
Windows® 7 (32 & 64-bit version with SP1 or higher)
Important Update
Fixed Issues
Known Issues
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Und auch nicht für die Carrizo-APUs, was mich nur noch ankotzt.
Schon vor einigen Wochen habe ich beschlossen, dass ich im Februar wohl meinen letzten Kauf eines AMD-Produktes getätigt habe.
Aber einen funktionierenden Treiber gibt es schon oder?
trosti
- Wuppertal
- MSI GX60 A10-5770, R9 290X, Crucial MX100 256GB, 2x4GB PC1866
- FX-9590
- Gigabyte 990FA-Gaming
- Cooler Master Seidon 120XL
- 4x4GB Patriot Viper 1866MHz CL9
- 2x Sapphire R9 390 Nitro
- AOC G2770PF
- Toshiba Q Pro 256GB, Samsung 850Pro, Samsung PM961 256 GB, Crucial MX200 250GB
- 1x Seagate Momentus 7200.14 3TB, 1x Samsung F1 1TB
- OnBoard
- Aerocool P7-C1
- Seasonic 1000W 80Plus Gold
- Win10 H 64bit
Für Carizzo? Klar gibts den, im Prinzip ist der doch eh "nur" für die APU und da man auf der normal nicht wirklich spielt, auch wens möglich ist, braucht man da nicht wirklich neue Treiber. Ätzend aber ist wen man den im einem Notebook hat mit dedizierter Grafik die einen von aktuellen Treibern unterstützt wird.
Den kann man dann nämlich auch nicht installieren. Das habe ich aktuell mit meinem GX60 Destroyer von MSI, deren Richland nicht mehr unterstützt wird aber die dedizierte R9 290X schon.... Die APU lässt sich beim GX60 nicht deaktivieren, auch nicht mit freigeschaltetem BIOS. Und das ist bei einem Gamingnotebook fürn arsch.
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Ja, der Catalyst 15.12 WHQL hatte als letzter Treiber eine Unterstützung für Carrizo dabei.
Allerdings macht mir Windows 10 Pro einen dämlichen Strich durch die Rechnung: Nach dem Aufsetzen des Betriebssystemes und der Installation sämtlicher Treiber (auch Catalyst 15.12) zimmert Windows Update ungefragt einen Treiber vom August 2015 ins System. Was das soll, verstehe ich nicht. Die seit Windows Vista enthaltene Funktion namens "Geräteinstallationseinstellungen" in den Systemeigenschaften hatte ich direkt nach dem Aufsetzen von Windows 10 deaktiviert, sodass eigentlich gar keine Treiber für Hardware in Eigenregie heruntergeladen werden dürfen.
Treiber vom Catalyst 15.12:
von Windows Update eingeschleuster Treiber, der seitens GPU-Z als Catalyst 15.8 interpretiert wird:
Jetzt kommt's: Mache ich über die Schaltfläche "Vorheriger Treiber" eine Rolle rückwärts, dann hat dies nur bis zur nächsten Update-Suche Bestand. Windows Update lädt einfach erneut diesen Treiber vom August des vergangenen Jahres herunter. Unterbinden kann ich es dank verkrüppelter Update-Funktion in Windows 10 nicht.
Ein 1300 Euro teures Notebook, das ich im Januar 2016 gekauft habe, nutze ich also mit einem Grafiktreiber vom August 2015. Ja, ich zocke auf meiner Maschine ein paar (weniger anspruchsvolle) Spiele.
Beiden Unternehmen möchte ich dafür am liebsten ins Hauptquartier kacken.
Unbekannter Krieger
- 4x4 GiB Hynix DDR3-1866 ECC
- TSST SH-222AL
- Win8.x x64, Win7 x64
Microsoft hatte doch im Zuge der Ankündigung, mit Win10 die Einstellungsmöglichkeiten von Windows Update noch weiter einzuschränken, verlauten lassen, dass es allerdings eigene Extra-Software anbieten werde, mit der man WU halbwegs steuern kann. Hast du die mal probiert? Und wie heißt sie überhaupt?Windows Update lädt einfach erneut diesen Treiber vom August des vergangenen Jahres herunter. Unterbinden kann ich es dank verkrüppelter Update-Funktion in Windows 10 nicht.
trosti
- Wuppertal
- FX-9590
- AOC G2770PF
- OnBoard
- Aerocool P7-C1
- Win10 H 64bit
Bei mir klappt das stoppen der automatischen Treiberinstallation eigendlich gut... man muss nur unter Systemsteuerung - Geräte und Drucker deinen PC rechtsklicken dann auf Geräteinstallationseinstellungen und dort nein anklicken... Da steht zwar was von Hersteller Apps und Symbole aber das gilt für Treiber ebenso.
Man kann Updates aber auch speziell ausblenden, das sollte auch bei Treibern funktionieren.
Dazu gibts ein spezielles Microsoft prog, muste mal nach googlen um die Zeit schläft mein Brain 2.0 schon
Außer direkt nach der BS Installation hat die Einstellung bei mir irgendwelche Treiberinstallationen verhindert.
trosti
- Wuppertal
- FX-9590
- AOC G2770PF
- OnBoard
- Aerocool P7-C1
- Win10 H 64bit
in wie fern?
Selbst wenn man installiert ohne Internet, und da die entsprechende Einstellung vorher setzt zieht Windows Update beim ersten Start trotzdem Treiber. Danach nicht mehr.
trosti
- Wuppertal
- FX-9590
- AOC G2770PF
- OnBoard
- Aerocool P7-C1
- Win10 H 64bit
Ah.. aber eher wurscht wen es danach die installierten Treiber in "ruhe" lasst.
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Nein, habe ich nicht, weil ich von dieser Software nichts weiß.
Von genau dieser Einstellung habe ich gesprochen. Nein, sie greift eben nicht - das habe ich oben bereits geschrieben. Unter Windows 7 und Windows 8.1 war die Option zudem noch sinnvoll unterteilt, was bei Windows 10 nicht mehr zutrifft.
Zuvor benannte Option unter Windows 7:
trosti
- Wuppertal
- FX-9590
- AOC G2770PF
- OnBoard
- Aerocool P7-C1
- Win10 H 64bit
Bei mir wirkts... und vor dem Oktoberpatch letzten Jahres war das auch noch unterteilt... ist aber dann eben zusammengezogen worden..
Wie gesagt, bei mir werden definitiv keine Treiber mehr eingespielt. Und wie auch erwähnt gibt es ein MS Tool mit dem du bestimmte Patches und Treiber ausblenden kannst.
Da du darüber nix weist, google einfach mal... dann findest du die auch sammt anleitung.
hier:
http://www.heise.de/newsticker/meld...-Tool-zum-Ausblenden-von-Updates-2763685.html
Dauerte 3 sekunden...
hier:
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Danke.
Nach dem vorherigen Beitrag habe ich natürlich selbst geschaut und Google befragt. Dauerte nur 2 Sekunden.
trosti
- Wuppertal
- FX-9590
- AOC G2770PF
- OnBoard
- Aerocool P7-C1
- Win10 H 64bit
Angeber
Achtung der Treiber ist erneuert worden, die Dateien haben 19. July im Filename und der Treiber hat ein WHQL Zertifikat. Post 1 ist erneuert.
Es gibt jetzt einzelne Downloads für die Windowsversionen und 32 und 64 Bit. Für Windows 8.1 wird weiterhin der Beta angeboten.
Viel Spass beim ausprobieren.
@eratte
Danke, hab die Beta Version 16.7.2 hotfix geladen, bin aber bisher nicht zum Installieren gekommen.
Somit noch mit der Beta Version 16.6.2 Unterwegs.
Wäre schön wenn sie den "Wattman" für meine Karten noch freischalten, der entsprechende I/O Chip ist ja verbaut.
Nosyboy
- Switzerland
- LENOVO Y520-15, Intel i7-7700HQ, W10-Home
- Ryzen 7 5700X / 7nm / 65W
- Sapphire Radeon RX5700 PULSE 8G
- Samsung C27FG70
- Pioneer BDR-209M
- on Board
- Chieftec Midi Tower
- Corsair RM550x
- Logitech G213
- WIN 10 Pro
- Opera / Edge
- ▼100 MBit ▲20 MBit
Bei mir unter Win 7 zeigt es auch immer noch Beta an...Achtung der Treiber ist erneuert worden, die Dateien haben 19. July im Filename und der Treiber hat ein WHQL Zertifikat. Post 1 ist erneuert.
Das kann ja sein, die Aussage ist ja nur:
Herrscht wohl im Moment etwas Chaos bei AMD, habe den Treiber gerade installiert (vorher noch der 16.4.2 WHQL):
16.7.3
Und richtig gesehen das auch die neue Version des 16.7.2(3) noch nicht für RX 480 und Windows 8.1 funktioniert, da also weiter den 16.30 Beta nutzen.
Rechner mit Windows 7 (vorher noch 16.3.2) meldet das auch so nach dem Update:
16.7.3
Sind die beiden Bilder oben vom selben System?Das kann ja sein, die Aussage ist ja nur:
16.7.3
Und richtig gesehen das auch die neue Version des 16.7.2(3) noch nicht für RX 480 und Windows 8.1 funktioniert, das also weiter den 16.30 Beta nutzen.
Windows 7 SP1 ? Willst nicht mal das 5 Jahre ausgereifte SP2 installieren?
Nosyboy
- Switzerland
- Samsung C27FG70
- Pioneer BDR-209M
- on Board
- Corsair RM550x
- Logitech G213
- WIN 10 Pro
- Opera / Edge
Interessant, bei mir stand beim Update immer 16.7.2 (beta).
Habe ihn jetzt mal installiert und nun steht : Aktuell installiert 16.7.3
Sollte es unter Updates nicht immer die aktuelle Version anzeigen...
trosti
- Wuppertal
- FX-9590
- AOC G2770PF
- OnBoard
- Aerocool P7-C1
- Win10 H 64bit
Komisch, bei mir steht nun nach der installation 16.7.2 ... warum hab ich da nicht 16.7.3? Fragen über Fragen ^^
Vor allem bei meinem System mit 2x R9 390 Sapphire Nitro wird 16.7.2 angezeigt bei meinem 2t PC mit ner R9 270X wird 16.7.3 angezeigt. Beides Win10 64bit.
Würde ich auch mal anraten, schließlich gibts doch für das SP1 keine Patches mehr wen ich mich nicht irre.
Ja
Freunde es gibt kein SP2 für Windows 7.
Du irrst dich.
http://www.heise.de/newsticker/meldung/Convenience-Rollup-fuer-Windows-7-Das-Nicht-SP2-3209742.html
trosti
- Wuppertal
- FX-9590
- AOC G2770PF
- OnBoard
- Aerocool P7-C1
- Win10 H 64bit
Oiweih.... da hab ich mich glatt mit dem XP SP2 verdaddelt, recht hast du natürlich!
Wohl eher mit Windows Vista, da gab es ein SP2. Bei XP war das letzte SP das 3.
