ATI Catalyst 8.6
- Ersteller cruger
ATI hat sein CATALYST Grafikkarten- und Chipsatz-Treiberpaket in der Version 8.6 zum Download freigegeben. Voraussetzung für das CATALYST Control Center (CCC*) ist unter Windows XP ein installiertes Microsoft .NET Framework. Eine aktuelle Version des .NET Framework kann man über die Microsoft Windows Update Seite beziehen.
<blockquote cite="http://game.amd.com/us-en/content/pdf/Catalyst_86.pdf"><i><b><u>New Features</u></b><br><br>Catalyst™ 8.6 introduces the following new features:</i><ul><li><i>OpenGL Adaptive Anti-Aliasing Custom Filters support</i></li><li><i>OpenGL CrossFireX™ (QUAD) support – 3 or 4 GPUs in CrossFire™ mode</i></li><li><i>Catalyst Install enhancement – No reboot required after Catalyst upgrade install</i></li></ul><i><b>OpenGL Adaptive Anti-Aliasing Custom Filters support</b></i><blockquote><i>This release of Catalyst™ introduces Adaptive Anti-Aliasing Custom Filters support for OpenGL applications for the ATI Radeon™ HD 3000 Series, ATI Radeon™ HD 2000 Series of products. Using the Edge Detect Custom Filter, users can enable 12X and 24X Anti-Aliasing. Selecting 4X Anti-Aliasing plus selecting the Edge Detect filter delivers the equivalent of 12X Anti-Aliasing. Selecting 8X Anti-Aliasing plus selecting the Edge Detect filter delivers the equivalent of 24X Anti-Aliasing.</i></blockquote><i><b>OpenGL CrossFireX™ (QUAD) support – 3 or 4 GPUs in CrossFire™ mode</b></i><blockquote><i>This release of Catalyst™ introduces CrossFireX™ QUAD support for OpenGL applications. Users with any combination of a ATI Radeon™ HD 3870, ATI Radeon™ HD 3850, and ATI Radeon™ HD 3870 X2 graphics accelerators running with 3 or 4 GPUs will be able to run in CrossFireX™ QUAD mode (when used in a CrossFireX™ compatible PC). Users are also able to run in CrossFireX™ QUAD mode while running in extended desktop mode on the Windows Vista desktop.</i></blockquote><i><b>Catalyst Install enhancement – No reboot required after Catalyst upgrade install</b></i><blockquote><i>This release of Catalyst™ introduces an enhancement to the Catalyst installer. Users are no longer required to reboot their system after Catalyst has finished installing (as long as the installation is an upgrade from a previous Catalyst install).</i></blockquote><i><b><u>Performance Improvements</u></b><br><br>The following performance gains are noticed with this release of Catalyst™.</i><ul><li><i>3DMark Vantage:10 to 15% gains across all Radeon™ HD 3xxx and HD 2xxx products, with larger gains in specific cases.</i></li><li><i>Call of Duty 4: Performance increases across all Radeon™ HD 3xxx and HD 2xxx products, with gains as large as 35% in specific maps.</i></li><li><i>Call of Juarez DX10: Performance increases between 2 and 9% across all HD 3xxx and HD 2xxx products</i></li><li><i>Company of Heroes (DX10 version): Performance increases between 4 and 10% across HD 36xx and HD 34xx products.</i></li><li><i>Lost Planet (DX10 version): Performance increases by 1 or 2 fps across all HD 3xxx and HD 2xxx products, creating in some cases up to 20% increase.</i></li><li><i>Lost Planet (DX9 version): Performance increases between 2 and 20% across all HD 3xxx and HD 2xxx products</i></li><li><i>Prey OpenGL: 3-5% gains across HD 3xxx and HD 2xxx products.</i></li><li><i>Quake 4 OpenGL: Up to 8% increase across all HD 3xxx and HD 2xxx products.</i></li><li><i>Shadermark 2.1: Minor improvements across all HD 3xxx and HD 2xxx products, with the largest gains appearing on HD 3650 (up to 9%)</i></li><li><i>ViewPerf 10: Substantial performance improvements across several of the sub-tests, with the largest gains in ugnx (up to 55%), catia (up to 17%) and tcvis (up to 10%) across all of the HD 3xxx and HD 2xxx products.</i></li></ul></blockquote>
Die Download-Links führen zu den Game.AMD.com Support-Seiten, wo man die Treiberpakete einzeln (Windows XP) oder aber komplett (Windows XP & Vista) inkl. CATALYST Control Center (CCC*) beziehen kann.
<b>Download:</b><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/common-vista32" target="b">ATI Catalyst 8.6 Display Driver [Windows Vista 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista64/common-vista64" target="b">ATI Catalyst 8.6 Display Driver [Windows Vista 64-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp" target="b">ATI Catalyst 8.6 Display Driver [Windows XP 32-Bit / MCE]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp64/radeonx-xp64" target="b">ATI Catalyst 8.6 Display Driver [Windows XP 64-Bit]</a></li></ul><ul><li><a href="http://ati.amd.com/online/mobilecatalyst/" target="b">ATI Catalyst 8.6 Mobility [Windows XP 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/mobility-xp" target="b">ATI Catalyst 8.6 Mobility Kompatibilitätsprüfung</a></li></ul><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/integrated-vista32" target="b">ATI Catalyst 8.6 Mainboard/IGP/Southbridge [Windows Vista 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista64/integrated-vista64" target="b">ATI Catalyst 8.6 Mainboard/IGP/Southbridge [Windows Vista 64-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/integrated-xp" target="b">ATI Catalyst 8.6 Mainboard/IGP/Southbridge [Windows XP 32-Bit / MCE]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp64/integrated-xp64" target="b">ATI Catalyst 8.6 Mainboard/IGP/Southbridge [Windows XP 64-Bit]</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://game.amd.com/us-en/content/pdf/Catalyst_86.pdf" target="b">Release Notes</a></li>
<li><a href="http://www.guru3d.com/article/atitraytools/189/" target="b">CCC* Alternative : Ray Adams' ATI Tray Tools</a></li><li><a href="http://www.microsoft.com/downloads/details.aspx?FamilyID=79bc3b77-e02c-4ad3-aacf-a7633f706ba5&DisplayLang=de" target="b">Microsoft .NET Framework 2.0 SP1 x86</a></li><li><a href="http://www.microsoft.com/downloads/details.aspx?FamilyID=029196ed-04eb-471e-8a99-3c61d19a4c5a&DisplayLang=de" target="b">Microsoft .NET Framework 2.0 SP1 x64</a></li></ul><sup>*) CCC = CATALYST Control Center; Erläuterung siehe <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1094139055">hier</a>.</sup>
Fonce
- AMD Phenom II X3 720BE
- ASRock AOD790GX/128M
- Noctua NH-U9F
- 4x1024MB DDR2-800 CL5
- Radeon HD 4850 512MB@650/1030MHz
- BenQ FP91GX
- Samsung HD753LJ
- Samsung SH-S223F/BEBE
- Antec Three Hundred
- Enermax 460W
- Windows Vista Ultimate 64bit
sehr coole Sachen was das sie schon wieder mehr performance aus der HD3000 und HD2000 Serie rausholen können
Stefan Payne
Dazu kann ich nur sagen:
Verdammte scheisse, gestern kam mein 780G Board, heute kam der 8.6er...
Den werd ich aber jetzt nicht testen...
skelletor
- Dresden
- einheimische Projekte
- Ryzen 7 5800X3D
- MSI X570-A Pro
- beQuiet DarkRock TF
- AMD Radeon 6900XT
- 1x 4TB WesternDigital Red
- Pioneer BluRay Brenner
- noname
- Seasonic X650 (80+ Gold)
- Swiftpoint Z
- Windows 10 Home 64bit
kein reboot mehr mit einer upgrade installation? geilomat!
AMD - saubere Sache, was ihr da mit den Treibern fabriziert...
und dann noch Performance aus den 2xxx und 3xxx Karten holen! sehr fein!
Nun verbleibe ich in der Hoffnung, dass ichn icht erst wieder auf den AGP - fix - Treiber warten muss...
gruß
skell
gruß
skell
Ole
...und das funktioniert?
skelletor
- Dresden
- Ryzen 7 5800X3D
- MSI X570-A Pro
- AMD Radeon 6900XT
- noname
- Swiftpoint Z
geht natuerlich nicht...Nun verbleibe ich in der Hoffnung, dass ichn icht erst wieder auf den AGP - fix - Treiber warten muss...
also doch wieder warten - oder per Hand ... naja grrrr - wie lang gibts die 3850 AGP schon? - Was soll der Quatsch mit der Extrawurst für die AGP´ler?
gruß
skell
lol mann muss echt nicht neustarten ... xD ist ja geil...... kommt nur das geräusch von hardware entfernt....paaar sek schwarz und dann wieder das geräusch von hardware installiert.....und nanu das bild ist da und der treiber installiert xD xD xD
sind wohl auch performancesteigerungen bei anderen komponenten zu erwarten? zB die 7xxer chipsätze?
sonnst muss ich gleich echt noch testen
ahso auch neue bilder und nen ander splash screen sind auch mit dabei xD also auch optische veränderungen
treiber startet überdies viel schneller das CCC
Beerman
Ich habe jetzt bei den Updates schon zwei mal das gleiche Phänomen: Antivir mag den Treiber nicht. (oder umgekehrt )
Bei den Updates bin ich folgendermaßen vorgegangen:
(inkl. diversen Neustarts nach Aufforderung)
Nach der Deinstallation war der Avira Antivir noch da, also das Sysmbol in der Taskleiste. (Meinte ich zumindest)
Nach der Installation und Neustart, ist mir aufgefallen, das der Avira Startscreen gar nicht mehr kam. Und das Taskleisten Symbol fehlte auch.
Auch eine Deinstallation und neue Installation von Avira half ersteinmal nicht. Dann kam zwar das Symbol wieder, allerdings wollte der Dienst nicht starten. In der Logfiles kam folgender Fehler:
Dann habe ich ihn nochmals deinstalliert und installiert. Immer noch das gleiche Problem, Symbol zwar da aber Regenschirm geschlossen (Dienst also nicht gestartet).
Erst nach dem Update (+Neustart) und dem Produktupdate (+Neustart) scheint Antivir wieder normal zu laufen.
Genau dieses Phänomen hatte nach dem letzten Update (auf Catalyst 8.5) schon einmal beobachtet. Allerdings nicht weiter beachtet, da ich auch einem anderen Grund Windows direkt danach neu installiert hatte.
(Diesmal hatte ich sogar den Virenscanner bei der Installation deaktiviert, das letzte mal nicht)
Kennt jemand das Problem?
BS ist Windows Vista 64
Avira war und ist in der neusten Version vorhanden.
- CCC deinstalliert
- Treiber deinstalliert
- Neuer Treiber installiert
- Neuer CCC deinstaliert
Fehler in AntiVir Guard.
Fehlertext: avgntflt
Fehlercode: [ <0x00000424> <0x000003E9> ].
Defragmentizer
- AMD Ryzen 7 3800X @stock
- ASUS ROG Strix X570-E Gaming
- Noctua NH-D15S
- 32GB (2*16GB Crucial Ballistix Sport LT 3200MHz CL16)
- Sapphire Radeon RX 580 8GB
- Samsung 860 Evo 500GB
- diverse
- Fiio K3 USB DAC
- Seasonic Prime SnowSiltent Platinum 650W
- Windows 10 Pro x64
ich pack hier mal meine beiden posts aus dem anderen 8.6 thread rein:
"klasse teil, auf meiner X1950Pro AGP poppt kurz der desktop auf, dann wirds schwarz, freeze.hab allerdings auch kein upgrade gemacht, sondern den alten vorher runtergeschmissen.naja, nach dem 7.8 und 7.9 prob ist jetzt mal wieder was neues. würd ja sonst langweilig werden, wenn alles dauerhaft mal auf anhieb gehen würde
bis einschließlich 8.5 gabs keine probs."
"beim upgrade von 8.5 auf 8.6 wollte er bei mir einen neustart.
naja, der 8.6 ist aber nach einigem rumprobieren wegen der freezegeschichte eh gestorben. kann doch nicht so schwer sein, dass was funktioniert auch funktionieren zu lassen
mal schaun, was der juli dann so bringt."
explizit hängt sie bei genau dem kurzen blackscreen, der nach einem reboot kommt (und bei dem wohl die karte initialisiert wird ) nur dass der nicht wenige sekunden dauert, sondern ein todestoß ist
Fusseltuch
- Intel C2Q6600 @ 3.2GHz
- MSI P35 Neo2-FR
- Alpenföhn Gross Clockner
- 8GB DDR2-800
- HD6850
- 24" Eizo SX2461W 1920x1200 / 21.3" Eizo S2100 1600x1200
- 160GB X-25M G2 2x 640GB WD6400AAKS 1x 500GB WD5000AACS
- LiteOn iHas120
- Antec P180
- Enermax Modu82+ 425W
- Win7 64bit
- Opera 11
Tatsächlich kein reboot nötig bei update. Und ja, ich finde das ein sehr nettes feature. Andere mögen ja gerne und viel booten, ich bin aber kein freund davon.
Läuft soweit alles rund. Ich kann mich dunkel daran erinnern das vor einigen monaten antivir bei mir nach einem neustart ebenfalls nicht automatisch gestartet wurde, aber ein erneuter reboot hat das problem behoben und kam dann auch nicht mehr wieder. Habe das eigentlich auch nicht mit dem catalyst in verbindung gebracht... aber jetzt wo du es erwähnst.
Auf alle fälle geht alles noch so wie es soll nach dem update auf 8.6
otti503
- Brohdworschdsiddi
- Ryzen5 3600X
- MSI Torpedo Max X570S
- Alpenföhn BROCKEN 3 :-))
- RX5700
- vorhanden
- aufm brett
- LIAN LI PC-B25B :-)))
- Win 10
- Firefox ;-))
LOL, jetzt ist die graka unter VISTA fast wieder genausoschnell wie sie vor nem viertel jahr unter XP schonmal war...
wollte übrigens durchaus einen neustart!
also viel wind um nix
cumec
- Schüttorf / Niedersachsen
- Simap, Spin
- Simap
- Phenom X4 @ 3000MHz
- Phenom II X6 1075T @ 3900MHz
- Gigabyte MA790GP-DS4H
- Gelid Tranquillo
- 8GB PC 800
- Saphire HD4850 - 512mb
- ViewSonic VA2216w / Eizo Flexscan L695
- 64GB OCZ Agility 2 / 1TB Samsung F3
- Samsung DVD-ROM 16x
- Chieftec Bravo BA-01
- be quiet! Straight Power E5 500W
- Win7 Professional 64bit / Ubuntu 64bit
- Fox 4
schon wieder solch enorme performancesteigerungen? ATI gibt bei den treibern nun aber echt gas!
gruß
cumec
gruß
cumec
Beerman
Einen Reboot habe ich natürlich auch versucht, nachdem ich es bemerkt hatte. Allerdings blieb das Symbol auch nach dem Reboot verschwunden.
Fusseltuch
- MSI P35 Neo2-FR
- 8GB DDR2-800
- HD6850
- LiteOn iHas120
- Antec P180
- Win7 64bit
- Opera 11
Hat immerhin ganze 13 postings gedauert bis sich ein hampel für diesen abgedroschenen spruch gefunden hat...
Makso
- Österreich
- Folding@Home, POEM, Docking
- Folding@Home
- Desktopsystem
- AMD Ryzen 5 1400@3,8GHz
- Asrock B350 Pro4
- Scythe Mugan 5
- 2x4GB ADATA
- RX 550
- BenQ 21,5
- Samsung 960Pro
- 1TB WD
- LG schwarz
- AC 97
- NZXT Beta Evo
- AXP SimplePower 630W
- Win 10
Interessant ist das schon mit dem Treiber! Ich hab schon getestet.
ALso meine ASUS EAX1659pro mit Originalen Treiber schaft in 3Dark05 4281 pkt.
Originaler Treiber 4281
Mit dem 7.9 4564 pkt.
Mir dem 8.5 7238 pkt.
Mit dem 8.6 7978 Punkte.
Also ich weiss nicht was ATI macht aber die Treiberupdates sind einfach genial!!!
An der Hardware habe ich nichts verändert!
cumec
- Simap, Spin
- Simap
- Gelid Tranquillo
- 8GB PC 800
- Fox 4
Gleich schnell sind die schon seit dem 8.3er
http://www.computerbase.de/artikel/software/2008/bericht_32_bit_64_bit_xp_sp3_vista/
mit dem 8.5er und dem 8.6er sollte Vista nun endgültig zu bevorzugen sein in Kombination Gamer und ATI!
gruß
cumec
Ole
Ich hatte zwar auch nen flackernden, schwarzen Bildschirm und eine Meldung, dass eine GraKa "wegen Treiberinkompatibilität" deaktiviert wurde aber nach der Installation wollte er einen Neustart.
Mag eventuell auch daran liegen, dass CF an ist und dazu die SB auch einen neuen Treiber bekam...
cumec
- Simap, Spin
- Simap
- Gelid Tranquillo
- 8GB PC 800
- Fox 4
bei mir unter vista64 mit einer 3850 und nvidia chipsatz wollte er keinen neustart.
corsair
Ich frage mich wie der Test auf Computerbase verlaufen waere, wenn wenigstens der 8.5er oder sogar der 8.6er benutzt worden waere.
garbel
Bei mir unter XP (32bit) SP3 mußte neu gestartet werden. Installierter Treiber war der 8.5'er; GraKa ATi 3850. Wann klappt das denn ohne Neustart und wann nicht?
Ole
Schätze mal, das das was mit dem Chipsatz zu tun hat. Wenn ein ATi oder AMD Chipsatz drinnen ist, der auch einen neuen Treiber über den Cat bekommt, dann wird wahrscheinlich neugestartet werden müssen.
cumec
- Simap, Spin
- Simap
- Gelid Tranquillo
- 8GB PC 800
- Fox 4
könnte auch OS-abhängig sein.
