- Foren
- Das Planet 3DNow! Archiv
- Anwender fragen, Hersteller antworten
- Themen-Nachmittag #9 & #12 : VIA Technologies GmbH
- VIA Companion Chips
Netzwerkchips von VIA
- Ersteller Darkstar007
Darkstar007
Was haben Sie denn für Netzwerkchips im Angebot?
Haben Sie auch Chips für Gigabit Ethernet im Angebot?
Wie wird bei Ihren Netzwerklösungen die Anbindung realisiert. Über PCI Bus oder anders? (Stichwort z. B. CSA, die Intel Lösung für geringe Latenzzeiten und PCI Entlastung) Haben Sie etwas ähnliches im Angebot/in Planung?
Marlo Banganga
VIA FAE Europe
Darkstar007,
I will take this in English if you don't mind. To answer your questions:
a. We do have VT6105M discreet LAN chip for example and we do have some additional LAN chips too. Kindly send a small note to me directly and I can send you more info about it. My email address is mbanganga@via-tech.de
b. Sorry but currently we don't have Gigabit Ethernet.
Thanks
In several network benchmark tests you can see, that esp. Intel and nVidia have very low CPU usage values, when accessing the LAN controller. VIA network interface chips are causing much higher CPU loads. A point, where gamers are very sensitive at the moment (ping, smooth frame rates). Is VIA aware of that "problem"? Will future VIA NIC chip cause lower CPU loads?
Marlo Banganga
VIA FAE Europe
K5-User,
Let me correct first my response I did release earlier. We do have Gigabit LAN chip, it's a new one.
As far as my knowledge, I haven't hear any problem with regards to this from my colleague. Let me check this one and come back to you. Kindly let me know your email address. Thanks
Thanks a lot. Don't wanna post my email-address in the forum. Would you please use the "PN" (Private Message) to reach me? Thanks for helpingOriginal geschrieben von Marlo Banganga
Marlo Banganga
VIA FAE Europe
Thanks a lot. Don't wanna post my email-address in the forum. Would you please use the "PN" (Private Message) to reach me? Thanks for helping![]()
You can contact me in my email address: mbanganga@via-tech.de. Thanks
MarcL
- Uralt Sony Vaio Irgendwas
- C2Q 9550 E0 @ 3,7GHZ
- ASUS Rampage Formula X48
- Scythe Infinity 2000
- 4G Kingston KHX8500D2K2/4G
- 2x ATI 4890 im CF
- 24" IIyama Prolite, Full HD
- Intel X25-M G2 Postville 160G & 2xSamsung 500G
- LG BDDVDRW GGC-H20L
- On Board SoundMaxx
- Antec P 182
- Seasonic 700W
- Win 7/64Bit
- Antec Lüfter durch Scythe Lüfter ersetzt
@K5-User:
Das würde mich auch interessieren ! Ich benutze zur Zeit den onboard Lan meines Soyo Dragon Plus, da ich hier noch eine alte Realtek 100 Mbit Lankarte rumfliegen habe würde mich interessieren wieviel CPU Last ich sparen kann. Der Ping ist bei mir bislang immer gut (15 - 30 ms QDSL). Hast Du Links ??
Gruss
Marc
English:
I've never heard of that before. I am currently using the onboard Lan of my Soyo Dragon + (KT266A) to play games and i have quite good pings. Could you give me some links to verify your statement because i have a Realtec 100 MB NIC lying around - would i benefit from a change to this NIC ??
Greetings
Marc
Gruss
Marc
English:
Greetings
Marc
OBrian
Moderation MBDB, ,
- Noctua NH-U12F
- 4 GB DDR2-800 ADATA/OCZ
- Radeon HD 5850
- NEC MultiSync 24WMGX³
- Samsung 840 Evo 256 GB
- Samsung SH-S183L
- BeQuiet 500W PCGH-Edition
- Windows 7 x64
Original geschrieben von MarcL
@K5-User:
Gruss
Marc
English:
Greetings
Marc
Realtek chips are also known to cause quite high CPU loads (there´s a reason why 3COM chips are not that cheap
), so that exchange wouldn´t help at all or even worsen the situation. But I assume you´re only using the NIC only for ADSL access, so with that pretty low bandwidth usage, there shouldn´t be much difference between any chips. However, I´d just try it.Ähnliche Themen
