Neuer Rechner kaufen oder warten?
- Ersteller cradle
cradle
Sind die Temps soweit in Ordnung im idle 4 Stunden und 30 min Prime95+furmark??
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.6.0
Monitoring
Mainboard Model X470 AORUS GAMING 5 WIFI-CF (0x000006CA - 0xCA2B2D98)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8686
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8686
LPCIO Revision ID 0x2
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 86 86 02 00 00 20 33 00 00 00 00 40 C8 58 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 40 0A 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A40
Hardware Monitors
Hardware monitor ITE IT8686
Voltage 0 0.79 Volts [0x42] (CPU VCORE)
Voltage 1 2.02 Volts [0xA8] (VIN1)
Voltage 2 2.03 Volts [0xA9] (VIN2)
Voltage 3 2.03 Volts [0xA9] (VIN3)
Voltage 4 1.10 Volts [0x5C] (VIN4)
Voltage 5 0.91 Volts [0x4C] (VIN5)
Voltage 6 1.38 Volts [0x73] (VIN6)
Voltage 7 1.64 Volts [0x89] (VIN7)
Temperature 0 33 degC (91 degF) [0x21] (TMPIN0)
Temperature 1 47 degC (116 degF) [0x2F] (TMPIN1)
Temperature 2 33 degC (91 degF) [0x21] (TMPIN2)
Temperature 3 40 degC (104 degF) [0x28] (TMPIN3)
Temperature 4 35 degC (95 degF) [0x23] (TMPIN4)
Temperature 5 39 degC (102 degF) [0x27] (TMPIN5)
Fan 0 889 RPM [0x2F7] (CPU)
Fan 1 0 RPM [0x0] (FANIN1)
Fan 2 746 RPM [0x389] (FANIN2)
Fan 3 110 RPM [0x17FF] (FANIN3)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 10 00 00 DF FF 00 20 FF 98 48 00 30 B0 FF 82
10 FE FF FF 77 C7 D0 C0 C0 02 FF 03 FF FF FF FF FF
20 41 A8 A9 A9 5C 4C 73 89 7F 21 2F 1E 28 23 27 80
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 46 00 5F 40 AD 6A D4 00 00 00 00 00
50 FF 18 7F 7F 7F 40 00 00 90 F1 19 12 65 00 00 00
60 00 14 41 66 1C 01 00 00 00 14 3C 7F 1C 01 00 FF
70 00 14 3C 46 1C 01 00 3E 00 14 3C 46 1C 01 00 C0
80 FF FF FF FF FF FF FF FF 00 00 00 00 00 F8 00 D1
90 00 00 00 00 FF 10 30 30 42 99 00 00 01 E3 F2 2D
A0 00 14 41 46 1C 01 00 D0 7F 7F 96 80 00 00 0F 98
B0 C5 29 89 7A 7F 7F 8A 00 8A 00 3C 3C 3C 3C 3C 3C
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor DIMM
Temperature 0 33 degC (91 degF) [0xC210] (core)
Temperature 0 35 degC (94 degF) [0xC22C] (core)
Hardware monitor Display API
Hardware monitor NVIDIA NVAPI
Voltage 0 0.85 Volts [0x352] (GPU)
Power 0 19.27 pc (GPU)
Temperature 0 52 degC (125 degF) [0x34] (GPU)
Fan 0 248 RPM [0xF8] (GPU)
Fan PWM 0 8 pc [0x8] (FANPWMIN0)
Clock Speed 0 1721.00 MHz [0x6B9] (Graphics)
Clock Speed 1 5005.80 MHz [0x6B9] (Memory)
Processors
Number of sockets 1
Number of threads 16
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- CCX 1
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
-- Core 6 (ID 6)
-- Thread 12 12
-- Thread 13 13
-- Core 7 (ID 7)
-- Thread 14 14
-- Thread 15 15
Timers
ACPI timer 3.580 MHz
Perf timer 3.613 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 8 (max 8)
Number of threads 16 (max 16)
Name AMD Ryzen 7 2700X
Codename Pinnacle Ridge
Specification AMD Ryzen 7 2700X Eight-Core Processor
Package Socket AM4 (1331)
CPUID F.8.2
Extended CPUID 17.8
Core Stepping PiR-B2
Technology 12 nm
TDP Limit 105.0 Watts
Tjmax 85.0 °C
Core Speed 4349.8 MHz
Multiplier x Bus Speed 43.5 x 100.0 MHz
Base frequency (cores) 100.0 MHz
Base frequency (ext.) 99.9 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision 0x8008206
L1 Data cache 8 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 8 x 64 KBytes, 4-way set associative, 64-byte line size
L2 cache 8 x 512 KBytes, 8-way set associative, 64-byte line size
L3 cache 2 x 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Fh
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 512 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 8 thread(s)
FID/VID Control yes
# of P-States 3
P-State FID 0x894 - VID 0x36 (37.00x - 1.212 V)
P-State FID 0x880 - VID 0x59 (32.00x - 0.994 V)
P-State FID 0xC84 - VID 0x76 (22.00x - 0.812 V)
PStateReg 0x80000000-0x494D8894
PStateReg 0x80000000-0x48164880
PStateReg 0x80000000-0x459D8C84
PStateReg 0x00000000-0x00000000
Package Type 0x2
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Power Unit 0.0
Attached device PCI device at bus 0, device 24, function 0
100 00000000 E0000001 00000000 00000000
110 00000083 00041000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 00000000 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
100 00000000 00000003 00000000 00000000
110 00100000 00100020 00100020 00100000
120 00100000 00000000 00000000 00000000
130 00000000 00000000 00100000 00100020
140 00100020 00000000 00100000 00000000
160 00001020 00000000 00000000 00000000
170 00000000 0000810D 00000000 00008105
180 00000000 00000040 00000000 00000030
190 00000000 00000040 0000003E 00000001
1A0 48201020 00000000 00000000 00000000
1B0 0003040C 00000048 00000040 00000000
1C0 00000020 00000034 01003030 00000000
1E0 00000004 0001014E 00000048 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
130 00010001 00010001 00010001 00010001
140 00010001 00010001 00010001 00010001
Attached device PCI device at bus 0, device 24, function 3
100 00000000 143F1FC2 0380FC40 00000000
Attached device PCI device at bus 0, device 24, function 4
100 00000000 0000015F 000009FF 000002BF
110 00400000 00010000 0001E000 0001FF01
120 0001FF00 00010000 0001FF02 0001FF07
130 0001FF03 00010000 0001FF02 00000000
180 000F0F0F 000F0F0F 001B1B1B 000F0F0F
190 000F0F0F 000F0F0F 00000000 00000000
Attached device PCI device at bus 0, device 24, function 5
100 00000000 04000000 00700281 00000000
190 00000008 00000100 00000000 00000000
1A0 00000000 00000040 00200000 00000000
Attached device PCI device at bus 0, device 24, function 6
130 00000000 00000000 FFFF0000 00000000
140 00000006 00000000 00000000 00000000
1F0 00000000 00000000 00000083 90000000
Attached device PCI device at bus 0, device 24, function 7
SMU Version 43.20.00
TDP/TJMAX 0x690055
TCTL Offset 0xA
Core Perf #0 0x52403671
Temperature 0 35 degC (95 degF) (Package (Node 0))
Voltage 0 0.79 Volts (CPU VDD (Node 0))
Voltage 1 0.77 Volts (VID #0)
Voltage 2 0.77 Volts (VID #1)
Voltage 3 0.77 Volts (VID #2)
Voltage 4 0.77 Volts (VID #3)
Voltage 5 0.80 Volts (VID #4)
Voltage 6 0.77 Volts (VID #5)
Voltage 7 0.80 Volts (VID #6)
Voltage 8 0.80 Volts (VID #7)
Power 00 22.62 W (Package)
Power 01 0.09 W (Core #0)
Power 02 0.05 W (Core #1)
Power 03 0.03 W (Core #2)
Power 04 0.06 W (Core #3)
Power 05 0.01 W (Core #4)
Power 06 0.02 W (Core #5)
Power 07 0.48 W (Core #6)
Power 08 0.24 W (Core #7)
Power 09 1.62 W (Cores)
Clock Speed 0 4349.77 MHz (Core #0)
Clock Speed 1 2174.89 MHz (Core #1)
Clock Speed 2 2174.89 MHz (Core #2)
Clock Speed 3 2174.89 MHz (Core #3)
Clock Speed 4 2174.89 MHz (Core #4)
Clock Speed 5 2174.89 MHz (Core #5)
Clock Speed 6 2199.89 MHz (Core #6)
Clock Speed 7 4349.77 MHz (Core #7)
Core 0 max ratio (effective) 43.5
Core 1 max ratio (effective) 43.5
Core 2 max ratio (effective) 43.5
Core 3 max ratio (effective) 43.5
Core 4 max ratio (effective) 43.5
Core 5 max ratio (effective) 43.5
Core 6 max ratio (effective) 43.5
Core 7 max ratio (effective) 43.5
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00800F82 0x00100800 0x7ED8320B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000011
0x00000006 0x00000004 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x209C01A9 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000D 0x0000000F 0x00000340 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x8000001F 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00800F82 0x20000000 0x35C233FF 0x2FD3FBFF
0x80000002 0x20444D41 0x657A7952 0x2037206E 0x30303732
0x80000003 0x69452058 0x2D746867 0x65726F43 0x6F725020
0x80000004 0x73736563 0x2020726F 0x20202020 0x00202020
0x80000005 0xFF40FF40 0xFF40FF40 0x20080140 0x40040140
0x80000006 0x26006400 0x66006400 0x02006140 0x00808140
0x80000007 0x00000000 0x0000001B 0x00000000 0x00006799
0x80000008 0x00003030 0x00001007 0x0000400F 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00008000 0x00000000 0x0001BCFF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF040F040 0x00000000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000003FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000001D 0x00004121 0x01C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x00C0003F 0x000000FF 0x00000000
0x8000001D 0x00004143 0x01C0003F 0x000003FF 0x00000002
0x8000001D 0x0001C163 0x03C0003F 0x00001FFF 0x00000001
0x8000001E 0x00000000 0x00000100 0x00000000 0x00000000
0x8000001F 0x0000000F 0x0000016F 0x0000000F 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010058 0x00000000 0xF8000019
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000A48A3
MSR 0xC0010064 0x80000000 0x494D8894
MSR 0xC0010065 0x80000000 0x48164880
MSR 0xC0010066 0x80000000 0x459D8C84
MSR 0xC0010067 0x00000000 0x00000000
MSR 0xC0010068 0x00000000 0x00000000
MSR 0xC0010069 0x00000000 0x00000000
MSR 0xC001006A 0x00000000 0x00000000
MSR 0xC001006B 0x00000000 0x00000000
MSR 0xC0010299 0x00000000 0x000A1003
MSR 0xC001029B 0x00000000 0x0D50BAB8
MSR 0xC001029A 0x00000000 0x00913B12
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x00800F82 0x01100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000001 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0xC0010293 0x00000000 0x000988A4
MSR 0xC001029B 0x00000000 0x0D5474B7
MSR 0xC001029A 0x00000000 0x00916C3A
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00800F82 0x02100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000002 0x00000101 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000A08A3
MSR 0xC001029B 0x00000000 0x0D582319
MSR 0xC001029A 0x00000000 0x00588048
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x00800F82 0x03100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000003 0x00000101 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x0D5BCFC8
MSR 0xC001029A 0x00000000 0x0058ABFE
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x00800F82 0x04100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000004 0x00000102 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000808A5
MSR 0xC001029B 0x00000000 0x0D5F7DB7
MSR 0xC001029A 0x00000000 0x0060D069
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x00800F82 0x05100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000005 0x00000102 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000A08A5
MSR 0xC001029B 0x00000000 0x0D632B98
MSR 0xC001029A 0x00000000 0x0060FA48
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x00800F82 0x06100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000006 0x00000103 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x0D66E6BB
MSR 0xC001029A 0x00000000 0x00661669
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
CPUID
0x00000001 0x00800F82 0x07100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000007 0x00000103 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x0D6A8DCD
MSR 0xC001029A 0x00000000 0x00663FA9
CPU Thread 8
APIC ID 8
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x00800F82 0x08100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000008 0x00000104 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000788A4
MSR 0xC001029B 0x00000000 0x0D6E36B9
MSR 0xC001029A 0x00000000 0x00596F35
CPU Thread 9
APIC ID 9
Topology Processor ID 0, Core ID 4, Thread ID 1
CPUID
0x00000001 0x00800F82 0x09100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000009 0x00000104 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x0008C8A6
MSR 0xC001029B 0x00000000 0x0D71E30C
MSR 0xC001029A 0x00000000 0x00599CB6
CPU Thread 10
APIC ID 10
Topology Processor ID 0, Core ID 5, Thread ID 0
CPUID
0x00000001 0x00800F82 0x0A100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000A 0x00000105 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x0008C8A5
MSR 0xC001029B 0x00000000 0x0D7596EB
MSR 0xC001029A 0x00000000 0x00634E63
CPU Thread 11
APIC ID 11
Topology Processor ID 0, Core ID 5, Thread ID 1
CPUID
0x00000001 0x00800F82 0x0B100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000B 0x00000105 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000848A6
MSR 0xC001029B 0x00000000 0x0D7947D3
MSR 0xC001029A 0x00000000 0x00637D75
CPU Thread 12
APIC ID 12
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x00800F82 0x0C100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000C 0x00000106 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000708A6
MSR 0xC001029B 0x00000000 0x0D7CF949
MSR 0xC001029A 0x00000000 0x0147B6A5
CPU Thread 13
APIC ID 13
Topology Processor ID 0, Core ID 6, Thread ID 1
CPUID
0x00000001 0x00800F82 0x0D100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000D 0x00000106 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000888A8
MSR 0xC001029B 0x00000000 0x0D80C33B
MSR 0xC001029A 0x00000000 0x0148698B
CPU Thread 14
APIC ID 14
Topology Processor ID 0, Core ID 7, Thread ID 0
CPUID
0x00000001 0x00800F82 0x0E100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000E 0x00000107 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x0D848402
MSR 0xC001029A 0x00000000 0x012C70EB
CPU Thread 15
APIC ID 15
Topology Processor ID 0, Core ID 7, Thread ID 1
CPUID
0x00000001 0x00800F82 0x0F100800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000F 0x00000107 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000888A5
MSR 0xC001029B 0x00000000 0x0D883DEE
MSR 0xC001029A 0x00000000 0x012CDA43
Storage
Drive 0
Name SanDisk SDSSDH3512G
Revision X6107000
Serial 181917801453
Capacity 476.9 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume e:\, 476.9 GBytes (64.6 percent available)
Drive 1
Name CT500MX500SSD1
Revision M3CR022
Serial 1828E149662A
Capacity 465.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume f:\, 465.7 GBytes (80.1 percent available)
Drive 2
Name ST1000DM010-2EP102
Revision CC43
Serial Z9AKR1LY
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume g:\, 499.6 GBytes (73.3 percent available)
Volume h:\, 431.9 GBytes (69.1 percent available)
Drive 3
Name WDC WD40EFRX-68N32N0
Revision 82.00A82
Serial WD-WCC7K4TAHZRA
Capacity 3726.0 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 5400 RPM
Features SMART
Volume d:\, 3726.0 GBytes (73.1 percent available)
Drive 4
Name Samsung SSD 960 EVO 250GB
Serial 3B7QCXE7472408D
Capacity 232.9 GB
Type Fixed
Bus Type NVMe (17)
Features
Volume c:\, 232.3 GBytes (79.6 percent available)
USB Devices
USB Device Intel(R) Wireless Bluetooth(R), class=0xE0, subclass=0x01, vendor=0x8087, product=0x0025
USB Device USB-Eingabegerät, class=0x00, subclass=0x00, vendor=0x0461, product=0x4D64
USB Device USB-Verbundgerät, class=0x00, subclass=0x00, vendor=0x04D9, product=0x1702
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Name NVIDIA GeForce GTX 1080
Board Manufacturer EVGA Corp.
Revision A1
Codename GP104
Technology 16 nm
Memory size 8 GB
Memory type GDDR5X
Memory vendor Micron
PCI device bus 10 (0xA), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x3842)
Model ID 0x1B80 (0x6286)
Revision ID 0xA1
Performance Level 0
Core clock 1721.0 MHz
Memory clock 5005.8 MHz
Monitor 0
Model Acer XB270H ()
ID ACR0405
Serial T1BEE0114205
Manufacturing Date Week 35, Year 2017
Size 27.2 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-160 kHz
Vertical Freq. Range 24-144 Hz
Max Pixel Clock 330 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8686
Config Mode LDN 0x4
Hardware Monitors
Processors
Number of sockets 1
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- CCX 1
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 5)
-- Thread 10 10
-- Thread 11 11
-- Core 6 (ID 6)
-- Thread 12 12
-- Thread 13 13
-- Core 7 (ID 7)
-- Thread 14 14
-- Thread 15 15
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
CPUID F.8.2
Extended CPUID 17.8
Technology 12 nm
Tjmax 85.0 °C
FID/VID Control yes
# of P-States 3
Package Type 0x2
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Power Unit 0.0
TDP/TJMAX 0x690055
TCTL Offset 0xA
Thread dumps
CPU Thread 0
APIC ID 0
CPUID
CPU Thread 1
APIC ID 1
CPUID
CPU Thread 2
APIC ID 2
CPUID
CPU Thread 3
APIC ID 3
CPUID
CPU Thread 4
APIC ID 4
CPUID
CPU Thread 5
APIC ID 5
CPUID
CPU Thread 6
APIC ID 6
CPUID
CPU Thread 7
APIC ID 7
CPUID
CPU Thread 8
APIC ID 8
CPUID
CPU Thread 9
APIC ID 9
CPUID
CPU Thread 10
APIC ID 10
CPUID
CPU Thread 11
APIC ID 11
CPUID
CPU Thread 12
APIC ID 12
CPUID
CPU Thread 13
APIC ID 13
CPUID
CPU Thread 14
APIC ID 14
CPUID
CPU Thread 15
APIC ID 15
CPUID
Storage
Drive 0
Revision X6107000
Serial 181917801453
Capacity 476.9 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 1
Name CT500MX500SSD1
Revision M3CR022
Serial 1828E149662A
Capacity 465.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 2
Revision CC43
Serial Z9AKR1LY
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Drive 3
Revision 82.00A82
Capacity 3726.0 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Drive 4
Capacity 232.9 GB
Type Fixed
Bus Type NVMe (17)
Features
USB Devices
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Revision A1
Codename GP104
Technology 16 nm
Memory size 8 GB
Memory type GDDR5X
Revision ID 0xA1
Performance Level 0
Monitor 0
ID ACR0405
Serial T1BEE0114205
Size 27.2 inches
Gamma Factor 2.2
ACPI
ACPI Tree
Bei gewöhnlichen Festplatten bietet bereits USB3.0 mehr Datenrate als die Festplatte liefern kann. USB 3.1 Gen2 bietet also keinen Mehrwert außer dass theoretisch mehr Strom übertragen werden kann. Aber ob und wie viel, legt die Spezifikation nicht wirklich fest, ist also Herstellerangelegenheit und da herrscht eh nur Chaos.USB 3.1 ROT
und USB 3.1 Type C
irgendwie verstehe ich den Sinn nicht ganz,
habe zwar USB 3.0 Platten und aus Spass mal am 3.1 Rot gesteckt, lesen und schreiben genau soviel wie am USB 3.0 Port.
Und das USB 3.1 Type c denke ich kann man nutzen, wenn man einen USB 3.0 Hub anschliesst mit 4 x 3.0 USB, das man dort quasi 4 USB 3.0 HDDS laufen lassen kann ohne extra Strom / Netzteil oder, da mehr Volt / Power drauf ist!?
Der Type-C-Stecker ist einfach nur ein anderer Stecker, der beliebig steckbar ist und Vorraussetzung für mehr Strom/Spannung.
Wenn Du alles andere außer den Temperaturangaben löschst, könnte man das vielleicht sehen.Sind die Temps soweit in Ordnung im idle 4 Stunden und 30 min Prime95+furmark??
- 50K
