AMD Radeon RX 6400/6500/6600/6650/6700/6750/6800/6900/6950 (XT) (Navi2x/RDNA2/PCIe 4.0): Tests/Meinungen im Netz. Links in Post 1
- Ersteller eratte
- Ryzen R9 9950X3D
Gozu
- Ryzen R9 5900
- 2x WDC WD10EADS-11P8B1
- TSSTcorp CDDVDW SH-2
- CoolerMaster HAF XB
- Enermax EDT1250EWT
- Rocat Kova
- Iron
- ▼1000 MBit ▲50 MBit
Acer stellt nun auch AMD Karten her:
videocardz.com
Acer launches Radeon RX 7600 Predator BiFrost series, its first Radeon GPUs - VideoCardz.com
Acer launches its first Radeon GPU The BiFrost family is expanding, the company has released three new cards today. According to the report, Acer is set to introduce three new graphics cards, one powered by Intel and two by AMD. Up until now, the Predator BiFrost series had only included the Arc...
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
AMD Radeon GPU Detective
Radeon™ GPU Detective (RGD) 1.0 is now available
Radeon™ GPU Detective (RGD) is our brand-new tool for investigating GPU crashes. RGD is included in the Radeon Developer Tool Suite and is available now!
Driver
Latest Adrenalin Software driver (minimum version 23.7.2)
Supported GPUs
Radeon™ RX 6000 series
Radeon™ RX 7000 series
Supported graphics APIs
Direct3D 12
Supported OSs
Windows® 10
Windows® 11
Supported GPUs
Direct3D 12
Supported OSs
Windows® 10
Windows® 11
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
AMD Software: Adrenalin Edition Preview Driver for AMD Fluid Motion Frames Release Notes (AMD)
AMD Fluid Motion Frames (AFMF) Technical Preview – Boost FPS with frame generation technology for a smoother gaming experience.
- AFMF adds frame generation technology to DirectX® 11 and 12 games on AMD Radeon™ RX 7000 (and now 6000!)Series Desktop Graphics Cards.
- We are responding to the excitement from our community and are adding support for Radeon™ RX 6000 Series Desktop Graphics Cards.
- AFMF preserves image quality by dynamically disabling frame generation during fast motion.
vinacis_vivids
- AMD Ryzen 9 7950X 16C/32T
- Samsung SSD 980Pro 2TB
- Creative Soundblaster ZXR
- Cougar DarkBlader X5
- InterTech Sama Forza 1200W
- Razer Mamba
- Windows 11 Education Pro
- Google Chrome
- ▼1000 Mbit
Forspoken: FSR 3
While I don’t disagree about not testing on AMD hardware, it’s far more likely the person doing the review didnt have an amd card on hand; which is still a huge oversight. It doesn’t necessarily make someone a fanboy. Correct. Maxus is based out of war-torn Ukraine. Did people assume I’m...
www.techpowerup.com
Watch Talos2DemoFSRvsDLSSRX6800 | Streamable
Watch "Talos2DemoFSRvsDLSSRX6800" on Streamable.
streamable.com
Das ganze "DLSS"-BS mit Ai und Tensor-Cores usw. ist eine einzige Marketing-BS von Nvidia. "DLSS" läuft unter Linux auch auf ner AMD RX6800.
Vielleicht kann das mal jemand nachtesten mit DLSS auf AMD unter Linux.
Gozu
- Ryzen R9 5900
- Rocat Kova
- Iron
Leider gibt es eine neue Version der Demo wo sich DLSS nicht mehr auswählen lässt mit AMD Grafikkarte.![]()
Forspoken: FSR 3
While I don’t disagree about not testing on AMD hardware, it’s far more likely the person doing the review didnt have an amd card on hand; which is still a huge oversight. It doesn’t necessarily make someone a fanboy. Correct. Maxus is based out of war-torn Ukraine. Did people assume I’m...www.techpowerup.com
Watch "Talos2DemoFSRvsDLSSRX6800" on Streamable.streamable.com
getestet auf dem ROG Ally unter ChimeraOS.
E555user
Ja natürlich ist das DLSS-Programm eine Verdummbeutelung der Kunden. Die Besonderheit von den sogenannten Tensor-Cores sind die (Tensor) Matrix-Multiplikationen in hoher Bitanzahl, damit die trainierten Werte möglichst korrekt sind. Diese werden aber nur beim Training von neuronalen Netzen wichtig. Das Inferencing, also das Anwenden eines trainierten Netzes kann in optimierten NNs mit weniger Bit erfolgen. Hierbei geht es vor allem um Latenz in der Verarbeitung wenn einzelne Werte durch das Netz "seriell gejagt" werden. Ich würde vermuten ein RDNA optimiertes NN müsste immer in den IF-Cache passen und alle CUs könnten dann mit packed Math in mehreren Pixeln je CU abarbeiten.
Am Ende sind es aber bei AMD, Intel und Nvidia die gleichen Instruktionen, die hier in HW angeboten werden. Für Inferencing sehe ich die CUs mit IF-Cache von AMD als sehr gut geeignet an. Linux kann da helfen einzelne proprietäre Konstrukte in Software aufzubrechen, auch das Drumherum in Algo zum NN. Gerade durch Proton/Vulkan als einheitliche API zum Hardware-Treiber ist das Drumherum gegeben, es bleibt das NN. Das optimierte NN muss auf die Instruktionen in niedrigen Bitzahlen und die Cache-Hierarchie der Zielarchitektur angepasst werden, wir brauchen also die trainierten NNs zu DLSS als ONNX. Oder das "proprietär optimierte" NN wird halt nur durch irgend eine offene API für andere Hardware zugänglich...
- AMD Ryzen 7 7800X3D
- MSI MPG X670E CARBON WIFI
- 32GB DDR5-6000 CL36
Das die meisten solcher Funktionen nur eine künstliche Abgrenzung sind und auch anderweitig umsetzbar wären sollte spätestens seit der PhysX Nummer klar sein.
Umgehungen für solche künstlichen Einschränkungen dürften eher an juristischen als an technischen Problemen scheitern.
- PrimeGrid@home
- ASRock 570X Taichi P5.50
Flutsch und weg
- Ryzen R9 9950X3D
Totgesagte leben länger:
AMD announces two Radeon RX 6750 GRE models at $269 (10GB) and $289 (12GB) (VideoCardz)
- Ryzen R9 9950X3D
AMD-Grafiktreiber: Codeschmuggel durch Sicherheitslücke möglich (heise)
Betroffen sind die Grafikkarten der Baureihen AMD Radeon RX 5000, 6000 und 7000. Dafür stellt AMD die korrigierte Version 23.9.2 (23.20.11.01) der Software Arenalin seit dem späten September bereit.
- Ryzen R9 9950X3D
Shinsaja
- Zwickau
- HP OmniBook 5 | Ryzen 7 350 | 32GB LPDDR5X-7500 | Radeon 860M
- AMD Ryzen 7 9800X3D
- Gigabyte B850 Gaming X Wifi6E
- be quiet! Dark Rock 5 / Silent Wings 4
- 32GB G.Skill Flare X5 6000MHz CL36
- XFX Radeon RX9070 Quicksilver 16GB
- Samsung G3 S32AG324NU 32"
- Samsung 990 Evo Plus 2TB
- be quiet! Pure Base 500 Window
- be quiet! Power Zone 2 750W
- Roccat Horde Aimo
- Roccat Kone Aimo
- Roccat Elo 7.1 USB
- ▼100 MBit ▲40 MBit
Wie schaut es eigentlich mit dem Thema aus, dass man das Bild einer z.B RX6600 über die IGP eines R7 5700G ausgeben lassen kann?
- Ryzen R9 9950X3D
- PrimeGrid@home
Welches Bild ?Wie schaut es eigentlich mit dem Thema aus, dass man das Bild einer z.B RX6600 über die IGP eines R7 5700G ausgeben lassen kann?
Auflösung, Farbtiefe, Komprimierung, Hz, Zertifiziert ?
DualGraphics läuft, aber halt mit allen Vor- und Nachteilen.
Shinsaja
- Zwickau
- Roccat Horde Aimo
- Roccat Kone Aimo
Dass was die Grafikkarte generiert. Nur Ausgabe über die IGP
DannyA4
- Ryzen 7 5800X
- GB X570 Elite
- Custom Wasserkühlung Aquacomputer
- 2x 16GB 3200 Crucial @3800CL16
- AMD Radeon 6900XT
- 3x Dell S2721DGF Triple Monitor Setup
- Corsair MP600, PCIe 4, 1 TB
- BeQuiet! Pure Base 500
- BeQuiet! Straight Power 11 850Watt
- Sharkoon Purewriter RGB
- Zowie FK1
- ▼200MBit ▲200MBit
Und was soll das bringen?Dass was die Grafikkarte generiert. Nur Ausgabe über die IGP
MusicIsMyLife
- in der Nähe von Cottbus
- Asteroids@Home
- Alltags-PC
- HP DV7-2225sg
- AMD Ryzen 9 9950X3D
- MSI MPG X870E Edge TI WiFi
- 4x 48 GB G.Skill TridentZ 5 TGB (F5-6400J3239F48GX2-RS5K)
- Sapphire NITRO+ RX 7900 XTX Vapor-X
- WD_Black XN850X 4 TB, Micron 9300 Pro 15,36 TB (U.2)
- keine, SSD only...
- Monster-Cube (2x Little Devil LD-PCV8 - individuell zusammengestellt)
- MSI MPG A1000G PCIE5
- ASUS ROG Strix Flare
- Steelseries Sensei 310
- Windows 11 Professional
- Brave
- ▼950 MBit ▲450 MBit
Einen geringeren Verbrauch im Idle bzw. unter Teillast, weil in einer solchen Konstellation die diskrete GPU komplett deaktiviert werden kann.
Siehe: Sockel AM5: Hybrid Graphics ausprobiert
- Ryzen R9 9950X3D
Neuer Previewtreiber vom 9.11:
November 9th - What’s New?
- Improvements to driver stability during task switching.
- Improvements to resolve cases of AMD Software: Adrenalin Edition™ intermittently crashing, or failing to display metrics.
- Ryzen R9 9950X3D
Extra Version nur für das Spiel
AMD Software: Adrenalin Edition 23.30.13.01 for Avatar: Frontiers of Pandora (AMD)
DannyA4
- Ryzen 7 5800X
- GB X570 Elite
- AMD Radeon 6900XT
- Zowie FK1
- ▼200MBit ▲200MBit
- Ryzen R9 9950X3D
Ja siehe auch unter Downloads
- Ryzen R9 9950X3D
- 36K
- 19K
- 102K
