- Foren
- Planet 3DNow! Community
- Team Planet 3DNow!
- Café Planet 3DNow!
NFS-Challenge 21.06. bis 26.06.
- Ersteller unterstudienrat
Kater Sylvester
- Reutlingen
- Constellation, Docking, Einstein, POEM, PrimeGrid, SIMAP
- Spinhenge
- 27 x Q9x50, 13 x i7 2x00K 20 x i7 3770K
- Dell Intel Mobile Core 2 Duo P8700@ 2,5 GHz 4096 MB
- Intel i7 2700K@4500 MHz
- Gigabyte Z68XP-UD5
- WaKü: EK-Supreme HF Kupfer, Hardware Labs Black Ice Radiator GT Xtreme 360, Eheim HPPS 12 V
- 4 x 4096 MB Corsair PC3-10700 (667 MHz), CMZ16GX3M4X1866C9
- Ati HD7970 3072 MB
- Eizo, L985EX 1600x1200
- Seagate ST23250823AS
- NEC ND 3500AG
- Chieftec CS2001
- Enermax Modu87+ 600Watt
- Windows 7 Professional 64
Hi Carlos Pinho
Today it is not so hot like the last days. Therefor I have switched on some computer and crunch now NFS@Home for a while.
On saturday we get 37 C again. Maybe, i have to switch off.
I think the L'Alliance Francophone Team has the same problem with the temperatur. The hot air comes over France to us.
Carlos Pinho
I know. Here in the UK we had last week a heat wave coming from the south of Europe. When I arrived from overseas (Brazil) in London was with 35/37 ºC (record from last 30 years).
Thank for the help, we appreciate it.
olsen_gg
- Stralsund
Hi Carlos, Is there a possibility to run the lasieve5f application also on Windows computers?
Carlos Pinho
Yes, now it is possible. Under any system you will need at least 1GB per thread.
olsen_gg
- Stralsund
Thanks. O.K., its running on my FX-8120 - 8 threads - its using more than 7 of 8GB RAM
I'm still watching and may be I have to reduce to 6 Threads (or to put in more RAM modules )
Carlos Pinho
Each instance will use up to 1GB, depends on the position of the range sieved. Right now it's using 850MB/thread on my machines.
olsen_gg
- Stralsund
That's right - I see the same on my machines. With 8GB and 7 Threads it is working smoothly.
So, ab heute Anbend werde ich dann wieder ein wenig reduzieren - der FX war eigentlich gar nicht geplant und geht deshalb wieder raus, statt dessen geht dann ein Athlon 5350 rein mit (wegen Speichermangel leider nur) 3 Threads.
bschicht86
- 2950X
- X399 Taichi
- Heatkiller IV Pure Chopper
- 64GB 3466 CL16
- 2x Vega 64 @Heatkiller
- Asus VG248QE
- 1x BH16NS55 mit UHD-BD-Mod
- Chieftec
- Antec HCP-850 Platinum
- Win7 x64, Win10 x64
Dafür hab ich mal 12 Kerne samt 32GB RAM ins NFS-Rennen geschickt
olsen_gg
- Stralsund
kernig
Carlos Pinho
Thank you for the current CPU power dedicated to NFS@Home. Can I request if utg can be reached to help us? I think utg can easily make more than 1M Boinc points per day.
Cheers,
Carlos
Cheers,
Carlos
Sabroe SMC
- Castrop-Rauxel
- AMD Ryzen 9 7950X3D
- Asus TUF Gaming X670E Plus
- Noctua NH-D15 chromax.black
- irgendeins
- Razer BlackWidow Ultimate
- Zowie Gaming Mouse FK1
▼500 Mbit/s
▲25 Mbit/s
That may be, but utg is not an active forum user. No one of us knows him. He's a ghost, a shadow, but a very good helper.Thank you for the current CPU power dedicated to NFS@Home. Can I request if utg can be reached to help us? I think utg can easily make more than 1M Boinc points per day.
Cheers,
Carlos
Carlos Pinho
Thank you.
In the meantime Syracuse University ramped up its numbers since a week ago and you guys are doing great. You are delivering a daily extra ~3000 16e Lattice Sieve V5 wus, that's awesome.
So thank you Planet 3DNow! team and keep crunching!!!
Carlos
Carlos Pinho
Just to give an update on the current sieve of 6,490+ (G6p490 files).
G means GNFS (general number field sieve) and "p" stands for plus (+).
Currently it was set to sieve up to q=2000M meaning that the workunits will go up to G6p490_2000000. We are currently at ~G6p490_1590000, which means we still have to process (2000000-1590000)/2000) wus (205k wus) + aborted ones. Overall is the number you see on "Unsent" for 16e Lattice Sieve V5. The sieve is the second stage to factor a number. After the sieve, we will have all data to try to create a matrix (linear algebra phase) so the post-processing (third stage) can be ran in parallel on a big cluster at University. The cluster used is usually a 512 node one with infiniband connection and we use it because he have a grant for it and it is impossible to run it through BOINC. This stage can take up to 1-2 months in a row (depends on several variables).
For next number, 2,1285-, we will need to process something like 1M wus.
Sabroe SMC
- Castrop-Rauxel
- irgendeins
▼500 Mbit/s
▲25 Mbit/s
Seems to be never ending work
Carlos Pinho
Which is good....NFS will be online for many and many years.
This case is pure advanced math and a very beautiful subject. It's going for records. It's completing the math tables since it started in 1925.
We appreciate all crunchers efforts.
Carlos
Carlos Pinho
2,1285- sieve has started. We will go up to q=2200M or 2400M, meaning we will have 1.09M wus to 1.19M wus to process. Can we sieve this integer in time record?!
For 6,490+ we hope to stop at q=1800M.
Thank you all for the CPU power deployed on this project.
Best Regards,
Carlos
Best Regards,
Carlos
Carlos Pinho
For the moment 2,1285- will only use less than 500MB of memory per thread.
joe carnivore
Thanks Carlos Pinho for the update.
That sounds good for eight core with 8 GB Ram.
Carlos Pinho
joe, right now it is consuming 600 MB per thread so within 1 week we will reach again the 850MB mark. In the meantime looks like LAF team is moving cores to NFS@Home because SkyNet POGS server dried out.
This is the perfect time to hit harder the NFS server.
Carlos Pinho
At current pace 2,1285- will be completely sieved within 100 days.
Carlos Pinho
Sorry for the late reply. Some comments from Greg the Admin.
1) Server issues: "I think I tracked down the database slowdown. Turns out that the size of the database, specifically the host table, has grown substantially thanks to Syracuse’s 1.8 million host entries. It became larger than the cache assigned to it, so records were being read from disk rather than memory. That’s bad. I increased the max cache size to much larger than the table, so things should be back to normal now."
2) Records: "As far as setting a new record, the current lasieve16e binaries aren’t up to the task. They came close to running out of steam on our current records."
Also " I need to take a look at the full data set I have now and set priorities for the next grant proposal"
So we are trying to check from the Cunningham Tables and on other projects where we can be of assistant inside the limits of the sievers, closer to record pinch.
Thank you all for your support.
I'll let you know what will be the next integer to sieve.
Keep crunching, we are still far away to finish 2,1285-, more or less 850k wus.
Carlos
Carlos
Carlos Pinho
Name: NFS@home Air Strike on lasieve5f Application
Status: Upcoming
Project: NFS@Home
Issued by: SETI.USA
Start time: 2015-08-28 00:00 UTC
End time: 2015-09-02 00:00 UTC
Late entrants allowed? Yes U
http://boincstats.com/en/stats/challenge/team/chat/704
http://escatter11.fullerton.edu/nfs/prefs.php?subset=project
Run only the selected applications lasieved - app for RSALS subproject, uses less than 0.5 GB memory: no
lasievee - work nearly always available, uses up to 0.5 GB memory: no
lasievef - used for huge factorizations, uses up to 1 GB memory: no
lasieve5f - used for huge factorizations, uses up to 1 GB memory: yes
Status: Upcoming
Project: NFS@Home
Issued by: SETI.USA
Carlos Pinho
Still more than 700k wus to process regarding sieving of 2,1285-.
Thank you for your support.
joe carnivore
Hello Carlos,
thanks for the info, but from 08/15/2015 - 08/29/2015 is the SETI WOW Event from Seti Germany.
http://www.seti-germany.de/Wow/44_en_Welcome.html
That means less power for NFS for this time.
Sorry for the bad school english.
Greetings
joe
Greetings
joe
heizzr
- Freiburg
- milkyway; Einstein; TN Grid; WCG;
- milkyway
- Ryzen 1700; Ryzen 2700; Vega 56 & VII; 6x Odroid U3; 4X Odroid C2
- Ryzen 1700 @ Stock
- MSI B350M Mortar
- Boxed
- 2X 8GB G.Skill Trident Z DDR4-3200 CL16
- Vega 56
- 28" Samsung U28E590D 4K Freesync
- 256GB ADATA Ultimate SU800
- 2TB WD Red WD20EFRX
- LG BH16NS55 Blu-ray Combo
- Realtek ALC 892 onbord
- Lian Li PC-A76wx
- 650W be quiet! dark power pro P9
- Win 7 64bit
If the US-boy`s come with an airstrike we have to set up our bunker
- 7K
