Download ATI Catalyst 9.10
- Ersteller cruger
ATI hat sein CATALYST Grafikkarten- und Chipsatz-Treiberpaket in der Version 9.10 für Windows XP, Vista und 7 zum Download freigegeben. Voraussetzung für das CATALYST Control Center ist unter Windows XP ein installiertes Microsoft .NET Framework. Eine aktuelle Version des .NET Framework kann man über die Microsoft Windows Update Seite beziehen.
<blockquote><b><font size="3">New Features </font></b><br>
<b>Official ATI Catalyst WHQL release supporting ATI Radeon HD 5800 series GPUs</b>
<ul><li>ATI Catalyst 9.10 now includes full GPU support for the award winning ATI HD Radeon 5800 series GPUS!</li></ul>
<b>GPU acceleration for the Windows 7 Drag and Drop video
converting application </b>
<ul><li>This release of ATI Catalyst™ provides GPU support for the Windows 7 Drag and Drop
video converter application found in the Windows 7 Operating System. This feature is
supported on the ATI Radeon™ HD 5800, ATI Radeon™ HD 5700 and ATI Radeon™
HD 4000 Series of products. </li></ul>
<b>Super Sample Anti-Aliasing for the ATI Radeon HD 5800 Series</b>
<ul><li>ATI Catalyst 9.10 provides support for a new Anti-Aliasing method on the ATI Radeon HD 5800 Series. Users can now experience the high level of anti-aliasing image quality using Super Sampling anti-aliasing while maintaining good performance levels.</li></ul></blockquote>
Die Download-Links führen zu den Game.AMD.com Support-Seiten, wo man die Treiberpakete einzeln (Windows XP) oder aber komplett (Windows XP & Vista) inkl. CATALYST Control Center beziehen kann.
<b>Download:</b><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-32-components" target="b">ATI Catalyst 9.10 Display Driver [Windows 7 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-64-components" target="b">ATI Catalyst 9.10 Display Driver [Windows 7 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/vista32-components" target="b">ATI Catalyst 9.10 Display Driver [Windows Vista 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/vista64-components" target="b">ATI Catalyst 9.10 Display Driver [Windows Vista 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/xp32-components" target="b">ATI Catalyst 9.10 Display Driver [Windows XP 32-Bit / MCE]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/xp64-components" target="b">ATI Catalyst 9.10 Display Driver [Windows XP 64-Bit]</a></li></ul><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/mobility-xp" target="b">ATI Catalyst 9.10 Mobility Kompatibilitätsprüfung</a></li></ul><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=Integrated/vista32-chipset" target="b">ATI Catalyst 9.10 Chipset Southbridge/AHCI/Raid Tool [Windows 7 & Vista]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=Integrated/xp32-chipset" target="b">ATI Catalyst 9.10 Chipset Southbridge/AHCI/Raid Tool [Windows XP]</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://www2.ati.com/relnotes/Catalyst_910_release_notes.pdf" target="b">Release Notes Catalyst 9.10</a></li><li><a href="http://www.microsoft.com/downloads/details.aspx?familyid=AB99342F-5D1A-413D-8319-81DA479AB0D7&displaylang=de" target="b">Microsoft .NET Framework 3.5 SP1</a></li></ul>
gruenmuckel
- Gerry-Weber - Stadt
- Collatz, Milkyway, POEM
- POEM & QMC etwa gleich
- Intel Core i7 6700K
- Asrock Z270 Extreme4
- Creative Recon3D PCIe
- Corsair RM650i
- Windows 7 64 SP1
- Firefox aktuelle Version
Dann bin ich ja mal gespannt ob dieser Catalyst in NFS: Shift spielbare Frameraten liefert.
Crashtest
- Leipzig
- Collatz, yoyo, radac
- yoyo
- Lenovo IdeaPad 5 14ALC05
- Ryzen 7950X / Ryzen 4750G
- ASRock B650M PGRT / X570D4U
- 27" Samsung LF27T450F
- KINGSTON SNVS2000G
- onboard HD?
- zu kleines für die GPU
- CHERRY SECURE BOARD 1.0
- Logitech RX250
- Windows 10 19045.7663 / 20348.5499
- Edge 152.0.4191.53
- U320 SCSI-Controller !!!!
- ▼1000 MBit ▲82 MBit
Warum den "alten" 9.10 installieren - wenn AMD selbst seit 10 Tagen beim Stream SDK 2.0 Beta den 9.11 RC anbietet ?!?
Longi
- AMD X4-955 BE
- Gigabyte MA770-UD3 (AM2+)
- 4 GB MDT-DDR2-800Mhz-AMDedit.
- ATI Sapphire HD4850
- 24" iiyama ProLite B2403WS
- Samsung 1 TB
- X-Fi - xtreme music
- NZXT Lexa blue
- Tagan 380W
- Vista x64 - HomePremium
- Fyahfoxx
Was hast du denn für ein System? *update - ah, sehs gerade - naja, dann halt wegen deines Prozis
ICH hatte einen X2-6000+ und eine ATI 4850 = unspielbar (mittlere Details in <1400x900 und trotzdem Ruckeln)
/me war somit auch am Schimpfen auf die Performance
Nun habe ich mir aber einen X4-955 BE gekauft und siehe da --> 1680x1050 alles high = flüßig!
Krass! Hätte ich gar nicht gedacht
Kann bitte mal jemand ausprobieren, ob der Trick, per Device-ID dem Treiber statt einer HD5k eine HD4k unterjubeln und dadurch das Supersampling aktivieren kann? Das sollte laut PCGH bei der Beta des 9.10 zumindest in OpenGL funktionieren. Wäre ja super, wenn es die Funktion in die finale Version geschafft hätte.
OBrian
Moderation MBDB, ,
- Noctua NH-U12F
- 4 GB DDR2-800 ADATA/OCZ
- Radeon HD 5850
- NEC MultiSync 24WMGX³
- Samsung 840 Evo 256 GB
- Samsung SH-S183L
- BeQuiet 500W PCGH-Edition
- Windows 7 x64
Ich hatte bei meiner 5850 den auch zuerst probiert, aber das CCC war im Eimer, mußte dann alles runterwerfen und mit DriverCleaner nachwischen. Mit dem offziellen 9.10 hier geht alles einwandfrei.Warum den "alten" 9.10 installieren - wenn AMD selbst seit 10 Tagen beim Stream SDK 2.0 Beta den 9.11 RC anbietet ?!?
cpushreder
- Hannover
- QuadCore Intel Core 2 Quad Q6600, 3510 MHz (9 x 390)
- Gigabyte GA-P35-DS3R
- EK Waterblock Plexi
- 2x G Skill F2-6400CL5-2GBPQ
- ATI Radeon HD 5770 (1024 MB) (Asus CuCore)
- Medion 23.6 Tft Akoya P55005 | Samsung SyncMaster 940NW [19" WS LCD]
- 2x SAMSUNG HD103SI (1TB) 2x SAMSUNG HD103SJ (1TB)
- HL-DT-ST DVD-RAM GH22NS30; TSSTcorp DVD-ROM SH-D163B
- Creative X-fi Titanium
- NZXT Whisper
- Nitrox 500w
- WIN7 x64
- Firefox V3.6
welches programm meinen die, den dvd maker oder den windows live movie maker?
SPINA
- AMD Ryzen 7 5700X3D (100-100001503)
- ASUS ProArt B550-Creator
- AMD Wraith Prism
- Sapphire Pulse Radeon RX 7600 8GB (11324-01-20G)
- LG Electronics 27UD58P-B
- Western Digital SN850X (WDS400T2XHE)
- HL Data Storage BH16NS55
- Lian Li PC-7NB
- Seasonic PRIME Gold 650W
- Debian 12.x (x86-64) Xfce
- ASUS TPM-SPI (Nuvoton NPCT750A)
Ich habe noch ein Windows XP Professional als Zweitbetriebssystem installiert. Als Grafikkarte kommt eine Radeon HD 4830 zum Einsatz.
Bei der Catalyst Suite 9.9 und 9.8 brach der Installer immer mit einer nichtssagenden Fehlermeldung gleich nach demEntpacken der Setup Dateien ab.
Die Catalyst Suite 9.10 ist nun die erste, die sich seit Version 9.6 installieren lässt. Ich frage mich nur, was die Ursache dafür war. Vielleicht die 8GB Arbeitsspeicher.
Menace
- World Community
- Ryzen R7 1700
- HP Elitebook
- AMD R7 1700
- Asus ROG Crosshair VI Hero AMD X370
- be quiet! Pure Rock Tower Kühler
- 16GB (2x 8192MB) G.Skill Trident Z
- AMD Asus R9Nano
- NEC EA232WMI, Benq SW2700PT
- Samsung EVO 500 GB, 2 x Samsungs EVO 1 GB
- 1 x WD6400AAKS
- LG
- Focusrite Scarlett 2i4 II
- be quiet! Silent Base
- 550 Watt be quiet! Dark Power Pro 11 Modular 80+ Platinum
- Vivaldi Developer
Ich frage mich, ob mit dem neuen Treiber jetzt das Problem mit Anno 1404 gelöst ist?
Irgendwie hege ich den Verdacht, dass die Leute, die das fragen, überhaupt kein Anno 1404 haben. Ansonsten würden sie doch schon vom Patch 1.1 für Anno 1404 gehört haben.
Diese Frage wird nämlich in diversen Foren sehr häufig gefragt.LostHero
- Osnabrück
- Medion Akoya P6630
- Intel Core i7 3770k (3,5Ghz)
- ASUS P8Z77-V Deluxe
- Prolimatech Genesis
- 2x8GB Corsair Vengeance (1866 Mhz @1,5V mit 9-10-9-27-2)
- Gigabyte NVIDIA Geforce GTX 680 (2GB)
- 27" ASUS VG278-X 120 Hz 3D Monitor
- SSD1: Samsung 840 Pro Series (512GB), SSD2: Intel X25 Postville (160GB), HDD1: 3TB, HDD2: 3TB
- LG BH10LS (Blue-Ray Combo Brenner)
- Creative X-Fi Titanium HD
- BitFenix ShinobiXL Big-Tower (gedämmt)
- Enermax Modu87+ (600 Watt)
- Windows 7 Professional SP1 (64 Bit)
- Puh zu viel...
Irgendwie hege ich den Verdacht, dass die Leute, die das fragen, überhaupt kein Anno 1404 haben. Ansonsten würden sie doch schon vom Patch 1.1 für Anno 1404 gehört haben.Diese Frage wird nämlich in diversen Foren sehr häufig gefragt.
Diesmal war ichs nicht
.LarsPower
- Hamburg
- Rosetta@Home
- Rosetta@Home
- Dell XPS 1730
- iCore7 2600K@4500
- Asrock Z86 Extreme 3 Gen 3
- EKL Brocken
- 4*4096 RipjawsX F3-12800CL9D-4GBXL
- Asus Geforce 680 GTX
- 27" Dell U2711 & 22" EIZO S2231 1600*1080
- OCZ Vertex2 120 Gig, Intel Postville G2 160 Gig, WD 640GB AAKS, WD 500 GB AAKS, WD 1000 GB
- Optiaric
- Creativ X-Fi
- Coolermaster Wavemaster
- Cougar SX 700
- Windows 7 Home Premium
Sagt mal hat der bei euch auch nur den CCC geupgradet? Ich hatte noch den Catalyst 9.8 drauf, den Displaytreiber hat der 9.10er aber nicht getauscht (Radeon 4870). Sehr komisch.
denjo
- Kellinghusen
- PDM <--- sowas gabs mal :(
- all
- Ryzen 7 1700, 3.60GHz
- 5700XT Nitro+
- LG UltraGear 27GL850-B
- Samsung 970 NVMe 1 TB
- bequite! PURE BASE 500
- Windows X
- Chrome, Firefox
- MEHR POWER ^^
- ▼600 ▲50
hab eine 4830 und shift läuft mit cat 9.9 alles high ruckelfrei !
kollege hat eine 4870 mit cat 9.9 und nen x2 6000+ läuft auch auf alles high und zwar ruckelfrei 8)
kenn diese problematik nicht
Drackenstein
- Intel Q9550
- Gigabyte GA-P35-DS4
- Intel Boxed
- 4GB Corsair XMS2
- Ati HD4850 GS
- 22" Asus
- 4x Samsung
- LGLG GDR 8164B black, LG GSA-H10N black
- Creative
- Antec P182
- Thermaltake 750W
- Win XP/Vista 64
leider wird die 5770 nicht von dem 9.10 für Windows XP erkannt.
ThW
- Dortmund
- AMD 5800X3D
- MSI MEG B550 UNIFY
- DeepCool Gammaxx L360 RGB V2
- 32 GB (4 x 8) Patriot Viper Steel DDR4-4400
- nVidia RTX 3090 FE
- 49" Samsung C49G94TSSU und 7" Aida64 Sensor Panel
- Corsair MP600 PRO 2TB M.2 NVMe PCIe x4 Gen4 SSD, 2 x Silicon Power PCIe M.2 NVMe SSD 2TB Gen3x4
- 2 x SanDisk Ultra 3D SSD 1 TB
- ohne (per USB im Notfall)
- Realtek ALC1220P Codec und Corsair VOID ELITE Wireless-Gaming-Headset
- Corsair Carbide Air 540
- LC Power LC1000P
- Lioncast LK30
- Sharkoon Skiller SGM1
- Win 11 Pro
- Opera (Alltag), Chrome (in Zusammenarbeit mit dem Smartphone)
- Corsair VOID ELITE Wireless-Gaming-Headset, TONOR Q9 USB Mikrofon, Logitech Z623 2.1-System
- ▼1 GBit ▲54 MBit
Ich habe leider -wie auch zum 9.9-Update- das Problem, dass sich unter Windows XP (MCE Edition 2005) keine Einstellungemöglichkeit für den Overscan-Modus bietet, weshalb ich rund um den Desktop einen schwarzen Rahmen habe...
Media-PC:
XP MCE 2005, SP 3, DirectX vom August 2009
ATI HD4350, 512 MB, PCIe
Media-PC:
b3n5n
- Haldensleben
- Acer Aspire One A150
- AMD Phenom II x2 550BE @x3 3500Mhz
- Gigabyte GA-MA790X-UD3P
- Scythe Katana II mit 120mm Lüfter
- 2x 1GB OCZ DDR2-1066 @800 2x2GB Corsair 800Mhz
- PowerColor HD6870
- Pilips 22" TFT 220E FullHD
- 1xWDC WD3200AAJS-00PSA0 (320 GB) 1xSAMSUNG HD200HJ (186 GB)
- HL-DT-ST DVDRAM GSA-H42N
- Realtek Onboard
- Chieftec Miditower
- OCZ StelthXstream 500W
- Windows 7
- FireFox 16 +Adblock,NoScript
zu nfs:shift
bei mir läuft es auch relativ flüssig in 1920x1080 und 2xAA wobei ich probleme bei fallout 3 habe -.-
