# dmidecode -t memory
# dmidecode 3.1
Getting SMBIOS data from sysfs.
SMBIOS 3.1.1 present.
Handle 0x0021, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: Multi-bit ECC
Maximum Capacity: 2 TB
Error Information Handle: 0x0020
Number Of Devices: 8
Handle 0x0029, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x0021
Error Information Handle: 0x0028
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMA1
Bank Locator: P0_Node0_Channel0_Dimm0
Type: DDR4
Type Detail: Synchronous Registered (Buffered)
Speed: 2667 MT/s
Manufacturer: Micron Technology
Serial Number: 1728A5C1
Asset Tag: P1-DIMMA1_AssetTag (date:17/20)
Part Number: 18ASF1G72PZ-2G6B1
Rank: 1
Configured Clock Speed: 2667 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Handle 0x002C, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x002B
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMB1
Bank Locator: P0_Node0_Channel1_Dimm0
Type: DDR4
Speed: 2667 MT/s
Serial Number: 1728BF98
Asset Tag: P1-DIMMB1_AssetTag (date:17/20)
Rank: 1
Handle 0x002F, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x002E
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMC1
Bank Locator: P0_Node0_Channel2_Dimm0
Type: DDR4
Speed: 2667 MT/s
Serial Number: 1728BFD1
Asset Tag: P1-DIMMC1_AssetTag (date:17/20)
Rank: 1
Handle 0x0032, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x0031
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMD1
Bank Locator: P0_Node0_Channel3_Dimm0
Type: DDR4
Speed: 2667 MT/s
Serial Number: 1728A712
Asset Tag: P1-DIMMD1_AssetTag (date:17/20)
Rank: 1
Handle 0x0035, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x0034
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMME1
Bank Locator: P0_Node0_Channel4_Dimm0
Type: DDR4
Speed: 2667 MT/s
Serial Number: 1728A42A
Asset Tag: P1-DIMME1_AssetTag (date:17/20)
Rank: 1
Handle 0x0038, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x0037
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMF1
Bank Locator: P0_Node0_Channel5_Dimm0
Type: DDR4
Speed: 2667 MT/s
Serial Number: 1728A5DA
Asset Tag: P1-DIMMF1_AssetTag (date:17/20)
Rank: 1
Handle 0x003B, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x003A
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMG1
Bank Locator: P0_Node0_Channel6_Dimm0
Type: DDR4
Speed: 2667 MT/s
Serial Number: 1728C143
Asset Tag: P1-DIMMG1_AssetTag (date:17/20)
Rank: 1
Handle 0x003E, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x003D
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMMH1
Bank Locator: P0_Node0_Channel7_Dimm0
Type: DDR4
Speed: 2667 MT/s
Serial Number: 1728C147
Asset Tag: P1-DIMMH1_AssetTag (date:17/20)
Rank: 1
