- Foren
- Planet 3DNow! Community
- Team Planet 3DNow!
- Café Planet 3DNow!
Boinc Games
- Ersteller enigmation
- PrimeGrid@home
- ASRock 570X Taichi P5.50
Das ist doch nur für 24-48h, steht doch auch da. Du siehst, dass unsere Boinc-Nutzernamen auch wieder normal aussehen. Sonst könnte ich mich für Windhund ausgeben.Aha, ich soll den Name in Boinc ändern. -> Delete Account.
Dann halt nicht![]()
Bis dahin sind wir durch, lohnt sich nicht mehr.
- Sit back and wait within 24 hours or sometime up to 48 hours for the CPID to be validated. The validation speed depends on the BOINC project select ed and how often the project stat is been updated.
Beim nächsten Mal wieder.
Und damit es beim nächsten Mal klappt, einfach jetzt schon die Prozedur starten, sonst bist Du ja wieder am gleichen Punkt.Bis dahin sind wir durch, lohnt sich nicht mehr.
Beim nächsten Mal wieder.![]()
That's only for 24-48 hours, it says there. You can see that our Boinc usernames also look normal again. Otherwise I could pretend to be greyhound.Aha, I should change the name to Boinc. -> Delete Account.
Then just do not
We'll be done by then, it's no longer worth it.
- Sit back and wait within 24 hours or sometime up to 48 hours for the CPID to be validated. The validation speed depends on the BOINC project selected and how often the project stat has been updated.
Next time again.![]()
Your best option would be to change your name to the unique name on as many projects as you can in hopes that one of them will update and validate your CPID sooner rather than later. Then you can change them all back once your CPID is verified.
- PrimeGrid@home
Thank you for the Info.That's only for 24-48 hours, it says there. You can see that our Boinc usernames also look normal again. Otherwise I could pretend to be greyhound.Aha, I should change the name to Boinc. -> Delete Account.
Then just do not
I have a lot CPIDs, so its alway tricky to find the active one.
But I get it. Thats not the Problem.
Temperature raising outside here, so I decide to couple out.
20k Points Avg in 6 hours is a fine sprint.
Thank you for the information.
I have a lot of CPIDs, so it's always tricky to find the active one.
But I get it. That's not the problem.
If you need help getting your CPIDs merged to one I can help.
The CPID is based on your email address. So you'll need to use the same email address on all the projects and attach all the projects to one host (the same host) and after a little time your CPID will all be merged into a single CPID.
If you do not wish to merge your CPIDs, then you'll need to register a new account for each one of your CPIDs. This will hurt your individual standings though since each CPID will be counted separately. But the team will be okay.
thorsam
Putzige Statusmeldung bei MilkyWay:
Benutzer neu regestriert in den letzten 24 Stunden: 7953
Computer neu regestriert in den letzten 24 Stunden: 108
Wenn ich die Zahlen von ydeeps mit denen von Boinc Games vergleiche, ist anscheinend jemand vom Team TAAT auch noch nicht Boinc Games beigetreten?
enigmation
Hm, schon komisch, keine Ahnung, wie die ihre Punkte sammeln aber solange wir da mehr machen, ist es mir auch recht![]()
The stats are only pulled from individual users who are signed up with a valid CPID on BOINC Games. It doesn't pull the the overall team stats.
One of our members with a high output on Milkyway jmpboy isn't registered on BOINC Games so his points are most of the points missing.
Landjunge
- bei Uelzen, NDS
- keins
- Intel Xeon E3 1230 V2
- AsRock Z77 Extreme4 - M
- Noctua NH-L12S
- 16GB 1866er G.Skill
- Philips 288E2 + Terra 1940
- defekt ausgebaut
- Silverstone Cube
- Windows 11 x64 Pro 22H2
- ReBar aktiv per ModBios
- ▼95 ▲37
Zweiter Platz!
Fazit: Nvidia Karten (außer Titan V) taugen nen Scheiß für MW
enigmation
FritzB
- Märkisch Kongo
- WCG, GPUGrid
- gute Frage
- 3x Ryzen 7950X, 9950X, 4800H, 7945HX, RTX 4070 Ti, RTX 4070 Ti Super, GTX 1650 Ti, RTX 4090, Radeon Pro VII
- mehrere
- 7950X, 9950X, 7945HX
- jeweils eins
- ganz viel DDR4 und DDR5
- LG UltraGear 27GP850-B
- diverse
- hatter
- Corsair, Seasonic, BQ...
- Windows 11 x64/Pro, Linux Mint 21.x
Einen Tusch für...
NumberFields@home
NumberFields@home
enigmation
FritzB
- Märkisch Kongo
- WCG, GPUGrid
- gute Frage
- mehrere
- jeweils eins
- diverse
- hatter
Vielleicht finden sich noch ein paar Mitstreiter. Vermutlich haben die meisten diesen Thread nicht abonniert und daher vom Start nichts mitbekommen
enigmation
olsen_gg
- Stralsund
Ein wenig NF kann ich noch beisteuern bis Heute Abend. Zum Glück laufen die ja nicht tagelang.
olsen_gg
- Stralsund
Oha. Endlich ausgeschlafen...
nicht Monat 07, sondern Monat 08.
O.K., dann kann ich das ja schon mal stoppen (No new work). Danke.
[automerge]1692181367[/automerge]
Dann eben ein wenig Asteroids, aber war da nicht was mit Linux besser als Windows?
An die einzige Linuxmaschine komme ich gerade nicht ran.
enigmation
Asteroids? Bin dabei.
Win/Linux-Unterschiede kenne ich nicht. Ich weiß aber, dass die die CPU recht gut auslasten, 100% Threads mit SMT nicht viel bringt oder vielleicht sogar negativ wirkt.
FritzB
- Märkisch Kongo
- WCG, GPUGrid
- gute Frage
- mehrere
- jeweils eins
- diverse
- hatter
Wer sich nicht mit den SSEx Apps rumplagen will, kann sich mit dieser app_info.xml auf AVX und CUDA118 WUs beschränken.
Die benötigten .EXE und .DLL Dateien gibt es unter
Code:
<app_info>
<app>
<name>period_search</name>
<user_friendly_name>Period Search Application</user_friendly_name>
</app>
<file_info>
<name>period_search_10213_windows_x86_64__avx_win10.exe</name>
<executable/>
</file_info>
<app_version>
<app_name>period_search</app_name>
<version_num>10213</version_num>
<avg_ncpus>1.00</avg_ncpus>
<max_ncpus>1.00</max_ncpus>
<flops>450000000000</flops>
<plan_class>avx</plan_class>
<file_ref>
<file_name>period_search_10213_windows_x86_64__avx_win10.exe</file_name>
<main_program/>
</file_ref>
</app_version>
<!-- CUDA -->
<file_info>
<name>period_search_10217_windows_x86_64__cuda118_win10.exe</name>
<executable/>
</file_info>
<file_info>
<name>cudart64_110.dll</name>
</file_info>
<app_version>
<version_num>10217</version_num>
<avg_ncpus>0.50</avg_ncpus>
<flops>1350000000000.000000</flops>
<plan_class>cuda118</plan_class>
<file_ref>
<file_name>period_search_10217_windows_x86_64__cuda118_win10.exe</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>cudart64_110.dll</file_name>
<copy_file/>
</file_ref>
<coproc>
<type>CUDA</type>
<count>1.000000</count>
</coproc>
</app_version>
</app_info>[/SPOILER]
Mir juckts ja in den Fingern, wenigstens einen Rechner anzuwerfen, aber ich sitze so schon nur noch spärlich bekleidet im Zimmer. Da kann ich eine zusätzliche Heizung gar nicht gebrauchen.
FritzB
- Märkisch Kongo
- WCG, GPUGrid
- gute Frage
- mehrere
- jeweils eins
- diverse
- hatter
- 16K
Aktuelle Aktionen
Pentathlon 2025
Forumsthread
Webseite SG Pentathlon
Projekt: World Community Grid
Forumsthread
Forumsthread
Forumsthread
