- Foren
- Planet 3DNow! Community
- Astronomie und Astrophysik
- MilkyWay@home
Optimierte MilkyWay@home Applikation
- Ersteller Twodee
JKuehl
- Stockholm, Schweden
- POEM, SIMAP
- SIMAP, POEM
- Q6600
- Ryzen-3700x
- Asus B350 Prime Plus
- Fractal Design Celsius 240
- 48 GB Corsair LPX 3000
- 1080ti
- 28" Samsung 3840x2160
- Samsung Evo 960 500Gb
- Creative X-Fi Titanium PCIe
- Be Quiet Dark Power 650
- Windows 10 64 Bit
Ich nehme dafür immer logmein.com dürfte enigen Zockenr durch HAMACHI bekannt sein die Firma
ICEMAN
- AMD Ryzen 3 2200G
- HP 255 G8
- AMD Ryzen 5 5600G
- PRIME B450M-A II
- Noctua NH-U9F
- AMD Radeon Vega 8
- 27" BenQ EW277HDR, 27" IIyama XU2793HS
- 1TB Samsung HD103SJ
- DVD-Brenner
- Windows 11 64bit
▼250
Habt ihr euch schon mal die readme gelesen, die bei der App dabei ist?
Man sollt vorher schon alles lesen und zwar bis zum Ende und dann fragen
Aber OK ich hab das sonst nicht getan
Known issues:
- not running with a protected mode (service) installation of BOINC under Vista/Windows7
- not running when machine is accessed via a remote desktop connection (use VNC
*without mirror driver* instead)
- graphics driver stops to respond (leeding to 2s freezes and/or VPU recover events) on some
OS/driver combinations if certain GPU monitoring tools are running, these include GPU-Z and the
Catalyst Control Center
- appears to run only with Catalyst 8.12 driver on some systems, WindowsXP versions (32 and 64bit)
of Catalyst 9.3 and up are known to be problematic, but are running under Vista though
- Some Vista/Win7 drivers (around Cat 9.5) have a bug in the CAL compiler giving the error message
"Failed to create Program" in the task details, updating to Cat9.9 fixes this
- somehow sluggish reactions of the Windows user interface
Note on Catalyst driver versions:
ATI/AMD renamed the CAL libraries with their later driver releases. You have to run the right
version which fits to the names of the CAL libraries of the driver release you have installed.
Catalyst 8.12 and 9.1 use the amd prefixed names, later ones use ati prefixed names (CAL 1.4).
If you choose the right version, there shouldn't be any need to meddle with the dll files. For
Catalyst 8.12 and 9.1 use the application variants with "_amd.exe" at the end, for newer drivers
simply use the files ending with "_ati".
But if you want to run the version designed for amd prefixed dll names to run with later drivers,
duplicate the following files in your Windows\system32 folder (the suffix "64" applies only to
64Bit systems):
aticalrt.dll or aticalrt64.dll
aticalcl.dll or aticalcl64.dll
aticaldd.dll or aticaldd64.dll
Now Rename the copies to
amdcalrt.dll or amdcalrt64.dll
amdcalcl.dll or amdcalcl64.dll
amdcaldd.dll or amdcaldd64.dll
The simplest way to do that is using the console (command prompt). Start -> execute, type "cmd",
press enter. Type in the following two commands:
cd %systemroot%\system32
copy atical*.dll amdcal*.dll
That's all. You should have now six dll files in your Windows\system32 folder, three named
amdcal*.dll and three with the name atical*.dll. A simple rename of atical*.dll to amdcal*.dll
is not sufficient!
McSven@SETI-Ost
Man sollt vorher schon alles lesen und zwar bis zum Ende und dann fragenAber OK ich hab das sonst nicht getan
Ups, ja das hatte ich mal gemacht als ich unter Win xp damit angefangen hatte (vor 9 Monaten oder so
kurz du hast mich erwischt, ich hätte mir das noch einmal durchlesen müssen.
Danke für die Tipps logmein.com und TeamViewer das werde ich bei Gelegenheit testen.
Aber meine GPU rechnet jetzt ihr 30k credits am Tag, da bekomme ich glatt auf eine Aktuelle GPU lust.
snicK
- Hessen
- Collatz Conjecture, Docking, QMC
Servus und noch ein Frohes neues Jahr,
ich hab nach längerer MW-Pause das Projekt mal wieder angeschmissen.
Nun habe ich auch die optimierten Applications eingefügt aber mein Q6600 braucht für die MW-WU´s knappe 5H
hat einer ne Ahnung an was dass liegen kann?
snicK
- Hessen
achso das erklärt einiges ^^
snicK
- Hessen
ich hätte da nochmal ein Problem ^^
bei einem 2. Rechner von mir nimmt er die optimierte app nicht an sondern lädt immer wieder die von MW runter und berechnet auch mit der.
Rechner hat einen Intel Pentium D Prozessor.
wenn mir da noch mal einer einen Rat geben könnte wäre dass sehr nett
JKuehl
- POEM, SIMAP
- SIMAP, POEM
- Q6600
- Ryzen-3700x
- 1080ti
- Windows 10 64 Bit
was kann ich denn noch an der CMDLINE schrauben um MW mehr Credits zu entlocken? System sollte noch responsiv sein und VLC o.ä. weiterhin laufen. Derzeit ist die CMDLINE leer und laut Rivatuner GPU-Auslastung bei rund 98% (geht da überhaupt noch was?)
JKuehl
- POEM, SIMAP
- SIMAP, POEM
- Q6600
- Ryzen-3700x
- 1080ti
- Windows 10 64 Bit
Ab heute wird wohl die "offizielle" ATI Unterstützung für MW geliefert - ändert sich was? Oder läuft die aktuelle Config mit der 0.20 und app...XML weiter ohne dass ich was tun muss?
http://milkyway.cs.rpi.edu/milkyway/forum_thread.php?id=1349#35119
JKuehl
- POEM, SIMAP
- SIMAP, POEM
- Q6600
- Ryzen-3700x
- 1080ti
- Windows 10 64 Bit
Database connect error.. also mal vorsorglich auf Collatz switchen! Ich laufe gleich schon leer...
gruenmuckel
- Gerry-Weber - Stadt
- Collatz, Milkyway, POEM
- POEM & QMC etwa gleich
- Intel Core i7 6700K
- Asrock Z270 Extreme4
- Creative Recon3D PCIe
- Corsair RM650i
- Windows 7 64 SP1
- Firefox aktuelle Version
Da saug ich die Staubfilter aus und will den Tempunterschied sehen und gleichzeitig fährt MW runter....
*grmbl*
*grmbl*
Sway Dizzle
Gibts ne Möglichkeit CPU und GPU (Nvidia) gleichzeitig laufen zu lassen?
LordNord
- S-H
- AMD Ryzen 7 5800X3D
- ASUS TUF Gaming B550-Plus
- be quiet! Dark Rock 4
- 2x16GB Crucial DDR4 3200
- AOC Q3279VWFD8
- 8TB extern
- Be quiet! Pure Power 9 600W
- Win 10 64Bit
▼200
▲200
1. http://milkyway.cs.rpi.edu/milkyway/
2. Dann ab in deinen Account
3. MilkyWay@home-Einstellungen
4. Edit MilkyWay@home preferences
5. Häkchen bei "Use CPU" setzen und Update Preferences drücken.
So sollte es gehen.
LN
So sollte es gehen.
LN
Sway Dizzle
Ich meinte ja mit der GPU und der optimierten App für cpu.
SoEinWahnsinn
Mal rein der Interesse halber.
Was hat es eigentlich damit auf sich
*KLICK*
*KLICK*
Code:
stderr out
<core_client_version>6.10.16</core_client_version>
SoEinWahnsinn
Das sieht bei etlichen Leuten so aus...
Ist ja jetzt auch kein Mangel an sich, mehr meine Neugier!
heimbuec
- Nordseeküste
- Rosetta
- Xeon 1230 v3
- AMD Ryzen 5 5600X
- MSI B450-A PRO MAX
- Standard
- 4 x 8192 MB DDR4 Crucial 3200
- EVGA GeForce RTX 3060 XC GAMING
- Viewsonic 32" TFT DELL 23"
- Samsung SSD 980 PRO 1000GB (M2)
- Pioneer DVD-Brenner + LG DVD-Brenner
- Soundblaster Audigy FX
- Chieftech Mesh CA-01B-B-SL
- BeQuiet PURE POWER L7 | 530W
- Windows11
- Edge
- Gehäuse gedämmt mit BeQuiet! Dämmmatten
Wenn du's rausbekommst, informier uns bitte! Danke!
Twodee
Lord of the Stats, Special, ,
afaik funktioniert das nicht, sobald du eine optimierte app (=anonymous plattform) benutzt - bestimmt die optimierte app worauf sie rechnet. wenn man inzwischen in der app_info.xml datei festlegen kann, das es mehrere apps gibt, nehme ich es zurück und behaupte das gegenteilIch meinte ja mit der GPU und der optimierten App für cpu.
Crashtest
- Leipzig
- Collatz, yoyo, radac
- yoyo
- Lenovo IdeaPad 5 14ALC05
- Ryzen 7950X / Ryzen 4750G
- ASRock B650M PGRT / X570D4U
- 27" Samsung LF27T450F
- KINGSTON SNVS2000G
- onboard HD?
- zu kleines für die GPU
- CHERRY SECURE BOARD 1.0
- Logitech RX250
- Windows 10 19044.5965 / Server 20348.3807
- Edge 137.0.3296.68
- U320 SCSI-Controller !!!!
- ▼1000 MBit ▲82 MBit
Wasn die akuellste CPU-Opti-App für K10 mit Windows x64 ?
etwa die "alte" von Seite 1 ?
SoEinWahnsinn
Scherzkeks
Hätte ich die Spur einer Ahnung, würde ich nicht hier fragen und auf Antwort von Gipsel warten..
Das sind WUs, bei denen die Parameter für die WUs wie für die neue MW3-Anwendungen per Kommandozeile übergeben werden. Die älteren Versionen verstehen das aber nicht (die erwarten die Parameter in einer Datei). Was man da sieht, sind einfach Warnungen, daß unbekante Parameter gefunden wurden.
Insgesamt ist das eher ein Problem mit der Server-Konfiguration, die die Parameter bei älteren Anwendungen (der Stand von MW3 ist ja noch nicht wirklich stabil zu nennen) sowohl per Datei als auch zusätzlich (und unsinnigerweise) per Komandozeile übergibt.
Schaust Du hier.Wasn die akuellste CPU-Opti-App für K10 mit Windows x64 ?
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- Thermaltake Silent Boost K8
- GeForce 6800 GT
- DVD-ROM / DVD-Brenner
- Creative Audigy
- noname
- Enermax Liberty 400W Dual
- Win98SE / WinXP SP3
Nein, da ist noch 0.16 verlinkt...die aktuelle 0.21 gibt's hier.
SoEinWahnsinn
Danke!
- 43K
- 42K
Aktuelle Aktionen
Pentathlon 2025
Forumsthread
Webseite SG Pentathlon
Projekt: World Community Grid
Forumsthread
Forumsthread
Forumsthread
